Mr clutch ? Any goo...
[Closed] Mr clutch ? Any good
[#7157012]
Need to replace the clutch on my T4 transporter..
Are they ok ?
Worried about them fitting cheap and nasty parts though expect they'd be no different to elsewhere.
Any experiences ?
Posted : 26/06/2015 2:55 pm
its a franchise.
some good some bad.
my local one has a terrible reputation so wouldnt get my car.
not all clutches are made equal either - id want a decent clutch and also there are many other items in there - seals and linkages that are best changed while its split or you end up creating extra work - again these need to be good quality items.
Look up your locals reviews on tinternet.... usualyl pretty revealing. take with a pinch of salt - 1 or 2 bad reviews to be expected..... but not the majority.
Posted : 26/06/2015 3:01 pm
 Andy
I used one in Reading. Terrible experience. ****** cowboys. Avoid.
Posted : 26/06/2015 3:05 pm
dire... avoid if near Bristol
Posted : 26/06/2015 5:15 pm
Peterborough one couldn't get it right first time or 2nd for me.
3/4th not in a straight line after two attempts
Posted : 26/06/2015 6:36 pm
Where are you based?
Posted : 26/06/2015 9:53 pm
Chichester.. Do nearest is Portsmouth
Posted : 27/06/2015 1:25 am
After watching Paul Calfs " Three Fights, Two weddings and a funeral" I thought Mr Clutch was a pi** take.
Posted : 27/06/2015 1:28 am
IIRC there's a good VW independent in Pompey near the footy ground. I can't remember their name and Google isn't showing anything. Perhaps a trip over and ask around?
Posted : 27/06/2015 5:11 am
Terrible... Huge staff turn over, poorly paid that could give 2 **** about your car.
Find a local VW specialist. After you get a price give a few VW main dealers a call clutches are one of those items that main dealers "sometimes" try to match independents to get the work. It's worth the call anyway.
Posted : 27/06/2015 6:59 am
Does it still drive OK
I work next to a garage staffed by a VW Transported fanboi who would probably do it for a swervy deal
You would have to supply your own clutch kit
New Alresford and I have a lovely 3hr loop to keep you entertained whilst he does the mucky bit if its a saturday afternoon job.
Can ask on Monday if you like , but Mr Clutch are cheap for a reason
Posted : 27/06/2015 8:41 am
Not even that cheap.....was 50 quid in it between mr clutch and my local independant ( not a vw)
I had him do the main seal , clutch cable and gear linkages with dealer sourced parts in thst price so well worth the 50 quid
Posted : 27/06/2015 8:53 am
As said above, they are franchised. They vary enormously - some are appalling, but others are even worse.
The one in Pompey is one of the better branches, but I still wouldn't trust them to fit a tyre valve cap, let alone a clutch.
Like most of the chain type garages they seem to prey on people who don't know any better.
Posted : 27/06/2015 9:09 am
quality - I may have to steal that 🙂
Posted : 27/06/2015 9:15 am
Any decent local outfit should be able to do it on any of the T4 variants, even if its had a 1.9 TDI transplant.
Posted : 27/06/2015 9:27 am
Thanks for the replies
I obviously have reservations about using them .. Hence my post I guess.
Problem is Mr Clutch are quoting £335 as opposed to my local garage charging ..£620
Posted : 27/06/2015 3:04 pm
Oof!
I suspect I'll need mine doing soon. Have been working myself up to having a crack on my own. Any spannerists like to comment on the difficulty of the job? Assuming you can work off the road etc.
Posted : 27/06/2015 3:17 pm
Derby lot are bang on. Did my tranny.
Posted : 27/06/2015 3:51 pm
Avoid, if you manage to find a branch that manages to fit the clutch without doing more damage, you will find that the clutch lasts about 10miles/5 days longer than the warranty and then expires.
Soft cheese is harder wearing than the clutches they fit
Posted : 27/06/2015 6:23 pm
I like Wrightysons comment - so many ways to take that!
Posted : 27/06/2015 6:41 pm
Quite. Bang on with a tranny's tranny 🙂
Posted : 27/06/2015 6:48 pm
Ok so here's my options
Mr clutch - £330
Independent garages x2 -1st £500
Second - £600
Main dealer - £870 ( incl) new flywheel
Blimey I'm not usually indecisive but what a wide range of prices ...???
Posted : 29/06/2015 4:54 pm
Are they mentioned on checkatrade website ?
Asked on VW forum somewhere ??
Posted : 29/06/2015 4:58 pm
 pk13
Get on the brick yard or vzi and ask for recommendations.
Posted : 29/06/2015 5:11 pm
I tend to avoid all businesses that are 'Mr .....' in the title.
Posted : 29/06/2015 5:41 pm
