Let's face it, the roadworthiness of a car 6 months post MOT can't be justified by the MOT, which only really applies on the day of issue. Even 24 hours later a fault could have occured which would be a fail.
Hobo, whats wrong about the receptionist/mechanic story? The mechanic falsified an MOT, he lost job. Sounds about right. The receptionist can ask all she likes.
Took my Mondeo into a main stealer for a service, purely to get the corrosion warranty box ticked so I could then take it into a Ford bodyshop and get all the rusty sills repaired. I'd haggled them down a little to match a Ford fast fit centre, I got the expected call mid-afternoon - "your brake pads need replacing, 75% worn, that'll be £350 please". I bought the pads from a motorfactors, replaced the rears which were about half the thickness of the new ones, but the fronts were 75% unworn! Sold the car a year later (with nice repaired sills) and the pads a few months after that on ebay.
I've heard some stories of what goes on in dealers, had a friend who did a stint as a salesman at Fords, constant stories of charging customers XXX for a dog guard then popping down halfords and getting a cheapo universal one, same with roof bars, and how his colleagues would up sell all the optional extras to squeeze every penny out of OAPs, how cars would come in with intermittent faults or service and the bare minimum gets done to them.
I also bought a car that came with a new MOT, took it back the following day with no damping action whatsoever in the rear shocks, airbag lights on (and a leaking gearbox gasket and slipping brand new clutch but thats not the MOT guys fault) Looked up the history on the MOT site, last three MOTs had an advisory list as long as your arm;
Windscreen has damage to an area less than a 10mm circle within zone 'A' (8.3.1a)
Brake hydraulic reservoir fluid close to minimum level (3.6.G.2b)
Front Brake disc(s) (3.5.1h)
Front Brake disc(s) slightly pitted (3.5.1h)
Front Brake pad(s) wearing thin (3.5.1f)
Air bag light on
All four shockers getting soft
And,
Nearside Front Brake pad(s) wearing thin (3.5.1f)
Offside Front Brake pad(s) wearing thin (3.5.1f)
Nearside Rear Shock absorber has a slightly reduced damping effect (2.7.5)
Offside Rear Shock absorber has a slightly reduced damping effect (2.7.5)
Offside at limit Windscreen has damage to an area less than a 10mm circle within zone 'A' (8.3.1a)
Airbag light staying on
Wiper blades showing age and have smear recommend replacing
N/s mirror damaged advise repair
Clutch release bearing noisy (and still noisy after replacement clutch)
Exhaust has part of the system slightly deteriorated (7.1.1a)
But somehow the latest MOT came with no advisories, despite still showing all the faults above, and coming with two visibly under-inflated tyres that were also underinflated on the test drive before it went for its MOT.
My van also came back from an MOT with a pass, despite me taking it in an asking them to replace dud bulbs for the rear number plate, x1 tail lamp, and x1 front marker lamp.
My Mondeo came back from a check on the suspension with a clean bill of health, no faults found, turned out the rear castor was seriously out causing uneven tyre wear and dodgy handling, sorted at another garage when I did some Googling on the symptoms and told them exactly what needed doing.
The only place I trust is the local 'Just MOTs' place, they failed my car once as it had a multi-colour headlight bulb in one side and a white in the other, how they noticed I don't know! Apparently both are OK, but must be the same fitted to both lights.
Spooky, is the irony of this guy who was sacked for dishonesty and then employed by the police not glaring
Yeh I saw that Hobo, but I got the impression you also thought it unfair that the receptionist kept her job whilst mechanic was sacked. My mistake.
Always thought the trick is to go somewhere that doesn't do repairs/parts, takes away the motivation to "find" something to fail. I work on the basis of trusting nobody, really, and it does seem to work.
The general perception is that a lot of garages have an integrity on par with that of estate agents & double glazing salesmen.
There's a lot of people around with tales of being hoodwinked, or simply ripped off.
Maybe they are all misunderstood or maybe they do have a particularly high number on chancers in their ranks
Certainly in the past there was massive amounts of fiddling going on in the motor industry, hence all the tight regulations to keep records of mileage etc.
The only thing I will post is:
Never go to Arnold Shark. Ever.
I once ripped them off 😆
i once put my ford orion in for mot, at a small independent garage,
it passed.
less than 100 miles later i noticed a grinding noise from the front when i used the brakes, got my dad to check it and it turns out the front pads were completely worn out!
(i had only passed my test a few months, and knew nothing about cars)
got it fixed by my dads m8, but i went back to garage that did the mot, informed them of the situ, and pointed out that if id known the pads were so worn they would have got the job of fixing them.
their reply was that id only asked for the mot, its not up to them to point out wear on components.
as a new driver, i think id rather have had the OPs experience, then at least i could make a guess as to what to do.
ps, garage went bust a couple of years later.
MOT is for roadworthiness at that point, it's not a service. Most garages would tell you, it costs them nothing after all and it's crap that they didn't- but you can't blame them that you didn't service the car right.
missingfrontallobe - MemberLet's face it, the roadworthiness of a car 6 months post MOT can't be justified by the MOT, which only really applies on the day of issue. Even 24 hours later a fault could have occured which would be a fail.
MFL - Spot on, an MOT only guarantees its roadworthyness at time of test
Martyn, the MOT tester is not allowed to remove any covers or do any dismantling etc so if he couldn't physically see the state of your pads he'd have no idea how worn they were. As long as it passed the rolling road test then job done (and I've seen pads with no material left on pass that test)!
