Mastic / sealant gu...
[Closed] Mastic / sealant guns
[#7080449]
If that's the correct term, those guns you put tubes of bathroom sealant etc in.
I seem to wreck them all the time. I've been using one whilst I do some sealing on the van so I'm after recommendations for a decent one that will last a bit longer with my heavy handedness 😳
Thanks
Posted : 21/05/2015 8:35 am
Cox sealant guns.
Posted : 21/05/2015 8:45 am
Find one of the plastic trim suppliers (euro cell, national plastics, etc) and get one from there.
They'll do a cheap one or a one for about £8.
Power pro I think there called. A bit heavier than the cheap ones but are very good.
Posted : 21/05/2015 8:51 am
The guy who installed our windows recommended the Cox guns, as above. You can get them in Screwfix.
Posted : 21/05/2015 9:17 am
Cox powerflow here. Got fed up with a cheap no-name gun that flexed and didn't give consistent flow. The easiflow will do most sealants fine though.
Posted : 21/05/2015 9:26 am
"Skeleton gun" is what I've always known them as.
Posted : 21/05/2015 9:29 am
I've got one that looks very much like a copy of the Cox was not much over £5 from one of the bargain shops. Works well. The key features are a rotating joint between the barrel and the trigger and a trigger made from a casting rather than folded steel.
Posted : 21/05/2015 9:32 am
Surely what you want is one of these
Posted : 21/05/2015 9:55 am
Looks to be a clone of the everbuild one I use at work. All the gun you should need.
http://m.screwfix.com/p/sika-power-pro-sealant-gun/86771
Posted : 21/05/2015 10:22 am
