So work takes me to Hereford Friday, AA Route planner tells me to go straight down via Shrewsbury etc.
My question is, what's the A49 between Shrewsbury & Hereford like? Reason I ask is I've been caught in the A Road Hell before & I'm wondering if the Motorway to Worcester & Then A/B roads might be an easier drive?
Any local knowledge greatfully recieved 🙂
Much nicer than the M6.
It's fine if you like travelling at 35mph 😉
will be about 8-9pm if that makes a difference?
Spot on..
I used to work in Hereford,and used to use this all the time.
I came back up this way about 2 weeks ago, and it was all good.
My brother is in the army and based in Hereford and I went to see him on Sunday gone, traveling from the Wirral and travelled on the A49 took 2.5 hrs and thats with Sunday drivers, if you like overtaking and driving quick you can probably do it in 2hrs.
I have travelled that way from home (liverpool) to afan. Takes a bit longer but the scenery is worth it anyday.
Is Afan worth it loddrik?
Cwmcarn is closer!
I live just off the A49, North of Shrewsbury is crap (I use it a lot to go to Wigan), south is better and generally quieter, plus the scenery is better, going to Abergavenny tomorrow so will be using it then.
spent 6 months going between cheltenham and Chester, started of using the M6 but not worth the hassle, going down through wrexham, oswestry, shrewsbury, is a much nicer route. It isn't much slower unless you get caught behind a tractor. The route did get more and more scenic as time went by, the pointless detour over the horseshoe pass for instance. Never got much slower.
Avoid, Avoid, Avoid the M6 on a Friday a ANY time. The A49 is a good run, plenty of opportunity to make progress 😉
Timc, absolutely!
Lovely drive, Liverpool to Hereford in under 3 hours including food stop... perfect!
