laptop advice neede...
[Closed] laptop advice needed
(Poor sod, broken laptop *and* busted by his mother, I almost feel sorry for him. Still, it's never to early to learn about offsite backups.)
Posted : 28/06/2011 2:11 pm
Oh.. aside from the silliness, have you checked the obvious external projector setting?
Posted : 28/06/2011 2:13 pm
how ?
Posted : 28/06/2011 2:14 pm
Make sure you tell him that you've specifically asked the repairman to search the hard disk for any important data he might have saved on there, and watch his face closely.
Posted : 28/06/2011 2:17 pm
Fn-F4 usually. It's not likely if you can see the power on screens but not the Windows splash (loading) screen. Ditto most of the other suggestions, which is why I was trying to clarify exactly what happens.
Cranberry > Naturally. (-:
Posted : 28/06/2011 2:23 pm
sometimes Fn+F8.
Posted : 28/06/2011 2:25 pm
sometimes Fn+F8.
I should've known that, given that that's what it is on this laptop. 😳
Posted : 28/06/2011 2:27 pm
On mine it's Fn+F7
Posted : 28/06/2011 2:28 pm
i've never come across a laptop that doesn't default back to LCD only on reboot so i doubt Fn+F? will do owt
Posted : 28/06/2011 2:34 pm
ok. i took it out into the garden so i could look at the screen better. i pressed buttons and also gave it a wipe as it was pretty grimy.
and yes i can see the windows screen with his name on it, just, it is very very dark, but it is there.
i couldn't see it before, when you guys first suggested it because i was indoors. and i didnt do the torch thing either.
but it i can defintaley see it now 😀
it's still not right though.
Posted : 28/06/2011 2:39 pm
It's the inverter then, as someone else suggested earlier. Given the history it might just be a loose cable, though they can be a right bugger to get at.
Posted : 28/06/2011 2:41 pm
(also,
... that's not grime.)
eeewww, i just wiped that off with my tissue 😐
Posted : 28/06/2011 2:46 pm
*tries very hard to ignore an open goal*
Posted : 28/06/2011 2:47 pm
thanks, you've saved me a lot of hassle. i would probably have just gone and bought a new laptop.
if you were me, what would you do now, how would you get it mended?
Posted : 28/06/2011 2:50 pm
tum-ti-tum
Posted : 28/06/2011 3:43 pm
Woohoo, I was right! Yeeha!
Changing an inverter is a fairly simple job as far as laptop fixings go, but if you're not confident taking it apart then don't even try because they are fairly intricate inside.
Should be a fairly low cost fix for a shop though.
Don't forget to tell your son that this latest version of Windows is designed to shut you out if it detects excessive masturbation
Posted : 28/06/2011 3:48 pm
I can sell you an earlier copy if that helps you out?
Posted : 28/06/2011 4:40 pm
Page 2 / 2
