Jigsaw blades for c...
[Closed] Jigsaw blades for cutting tiles
[#7465428]
Random question of the day.
Has anyone any experience of the Vitrex tile cutting jigsaw blades?
Thanks
Posted : 19/11/2015 9:59 am
Depending on what you are cutting I found them pretty useless and prone to chipping or cracking the tile. Heavy tiles I wouldn't even contemplate using them.
Not sure what you are wanting to cut out but find using a tile disc on an angle grinder, tile nibblers and a file I can create most cut outs much quicker and neater.
Posted : 19/11/2015 10:06 am
Depending on what you want to actually cut - you may want to take a look at the Dremel tile cutting attachment and bit - it works very well for intricate cuts on normal wall tiles.
Posted : 19/11/2015 10:14 am
Thanks all.
Was to cut a narrow strip lengthwise off tiles that my scoring wheel cutter can't handle.
Shall have to invest in a wet saw.
Posted : 19/11/2015 10:19 am
For occasional use may be better bet to buy one of the cheaper tile saws [url= http://www.screwfix.com/c/tools/tile-saws/cat830868?cm_mmc=Google-_-Power%20Tools%20|%20Saws%20and%20Woodworking%20|%20Generic%20-%20Non-RLSA-_-Saws%20-%20Tile%20Saws%20-%20Exact-_-tile%20saw&gclid=COH8veKTnMkCFYyRGwodRYQOAA ]they start from £30.[/url]
This was my plan before I found a neighbour had one that I could borrow. Tried a jigsaw blade before and it was useless.
Tile saw is the right tool. Ask around your mates/neighbours or look 2nd hand as loads of people buy them for a one off job then stick them in the loft. If you are near Bristol you can borrow mine.
Posted : 19/11/2015 10:23 am
Thanks for the offer but am in W Sussex.
Trip to Screwfix it is then.
Posted : 19/11/2015 10:30 am
I used a Dremel for cutting tiles when I did the kitchen.
There were no curved cuts, but it cut the subway tiles easily.
I used a diamond disc bit and a tile cutter bit.
Posted : 19/11/2015 12:50 pm
I used a hand tile saw and a tile drill bit to cut a lovely curved shaped in a tile. Cheap and very effective. Didn't take too long, either.
Edit : Blade was something like this for a mini hacksaw...
http://www.diy.com/departments/bq-tungsten-carbide-tile-saw-blade/38102_BQ.prd
Posted : 19/11/2015 12:54 pm
