Jesus phone help!!!...
[Closed] Jesus phone help!!!!!
[#3047008]
Right three or four times this morning, up has flashed a message saying "this device is not optimised for use with I phone and may affect your data and cellular" or words yo the effect. I've only seen that before on the old I phone when connected to a cheapy dock!! However as we speak this isn't connected to anything!
Posted : 14/08/2011 10:06 am
Blow on the contacts maybe something is causing to think it's connected.
Posted : 14/08/2011 10:08 am
What's the question?
Posted : 14/08/2011 10:09 am
Have just blown in it's hole, see if that remedies it!! 😉
Posted : 14/08/2011 10:12 am
Jesus phone?
Posted : 14/08/2011 10:27 am
Most likely a small piece of foil or something else conductive has gone from your pocket into the dock connector so it thinks it's plugged in. Get a needle, toothpick or similar and dig out the fluff and rubbish in there.
Posted : 14/08/2011 10:30 am
Vacuum cleaner.
Posted : 14/08/2011 10:31 am
External devices that are approved by apple have an authorization chip inside to [s]ensure apple make even more cash through licensing[/s] prove it's a compatible product. If Drac's suggestion doesn't cure the problem you could have a dry joint or a short inside the phone where this is detected. Shake it about a bit 😉
Posted : 14/08/2011 10:35 am
D'oh, sorry guys. Looks like funnychill.com don't find it very funny to have their pics used on a forum 🙁
Posted : 14/08/2011 11:06 am
Shoulda gotta HTC..... 😉
Posted : 14/08/2011 11:19 am
Yep. Then you would have had no devices at all that can dock with it, so you wouldn't have an issue 🙂
Posted : 14/08/2011 12:40 pm
Give it a good boil wash - no silly messages after that I assure you.
Posted : 14/08/2011 12:45 pm
