...any insurance implications...
Sometimes you'll need to drive into a closed road for access to a property. Driving into an obvious flood is a different car-full of fish
Admiral insurance flood advice
If you’ve got time and effort invested in it the it sounds wiser to put another engine in the van rather than all those bits into another vehicle.
I've not got the skills to swap an engine myself, and paying someone to do it will probably cost more than the van is worth. I can take the leisure battery and electrics and a few other bits back out though.
Did you get it priced up? Van prices have got a bit silly the last couple of years.
Sorry for another gratuitous Rufford Ford video
I'm quite enjoying them in a "WTF are they thinking" kind-of way.
Jesus that is a serious amount of oil leaking out that beemer!
tillydog
Free MemberLike this guy? 😀 (5:20 if it doesn’t go there)
Can't believe how rude the first van is- you always give way to ducks when you're driving on a waterway!
We were out on the weekend. Bear in mind the 110 is bog standard and has no snorkel….
Depending on the generation, even a standard defender has a useable wading depth of about 900. With skill and getting the right bow wave you can take them deeper (at your own risk).
Think the manual quotes 600mm, but at that depth you can park up, stop the engine and go for a walk if you want. Idiot proof at 600mm.
FWIW, a lot (lot lot lot) of recent faux by fours have incredibly low intakes, all in an attempt to get some air into the engine that hasn't already been used to cool the radiator. Using small, highly stressed, high specific power output engines doesn't help, lots of cooling needed, lots of emissions equipment as well. Not surprising that a saloon/estate has quite a low intake. Sticking it behind/below the bumper is a joke though...
Possibly a holed crank case when the conrod snapped, or maybe filled the diff casing with water. Or knocked something loose with all the water rushing into the engine bay.
Idiot should have their licence taken off them.
I was hoping this was an update about OP's van being fixed.
I think 98% of us londoners vans are now toast...since that idiot mayor wants to expand ulez to greater London....im now going to be proper fuct...perfectly good working 2009 vw caddy...from next year sometime I won't be allowed to use anymore unless I cough up daily...jeeeez
