My wife tried to send a picture to someone on her iPad and it hasn't sent. It seems to be constantly trying to send it and the little wheel just keeps spinning round at the top of the screen. Is there any way to delete it because it seems to be affecting everything in her emails.
Have you tried switching it off and back on again?
Yes. Tried that. Still the same.
Close email program properly and load again. Switching on and off may also help as above.
It'll probably be sat in her Outbox.
If you hit "Mailboxes" in the mail app it should take you up a level where you can then see all the folders (not just your inbox). You can then delete from Outbox.
There doesn't seem to be an outbox.
There's a sent box and a drafts box but it's not in either of those.
Have you doule-clicked the home button and swiped the email app off to close it?
If it continues to be pain she could upload it to a pic hosting site like imgur (there is an app) and copy/paste the link.
Granted it's more fiddly, but it may work.
Have just tried that.
Still no good.
I'm now getting the message 'the mail server is not responding. Verify that you have entered the correct account info in mail settings'.
I've checked it and everything seems to be OK.
Reset?
Hold the home and lock buttons down together until the apple appears. That should sort anything.
Maybe the mail server is actually down?
If we hold the buttons down together, does it just reset the iPad rather than delete stuff off it?
Oooh my turn.
We have 2 ipads and a mac book. They all have same outgoing mail settings but only one ipad will send mail.
My samsung phone and nexus have same settings and both work. I even had someone who knows about this stuff have a look and they had no idea. What about the brainiacs on here , any thoughts?
Holding both buttons is a hard reset, but it doesn't delete anything. You got to settings and need a password to do that.
This may sound nuts but go to your mail settings, delete the outgoing server and then reinstall it - apparently this works for many providers but certainly fixed a similar problem for me with talktalk.
AS Nobby says delete the account settings then reenter them, it's an occasional bug that happens. Also you can try entering the wrong password let it try to connect then when it fails enter the correct one.
For outbound email to work, you either have to send securely (ie, enable encryption / authentication) or use your ISPs SMTP server settings rather than your email provider's server.
the former is preferable on a mobile device as it should then work anywhere, not just at home. I don't know where the settings are on an iDevice but there should be a tick box somewhere.
open the mail account
scroll down to where it says outgoing mail server - SMPT
click on the option under primary server and 4th box down is password - this needs to match your mail account password.
my guess is your wife has changed her email password recently - and only reset the mail password on the first screen when you enter the account.
removing the email account and reinstalling it does this act for you but much easier just to change the password.
SMTP, not SMPT (or SNMP as I originally wrote before I'd had coffee).
i dont know about these things - i just had the same issue when i found an email sitting in my outbox on my phone i sent to stoner yesterday.
turns out id changed my email last week and that bit still had my old password in .... changed it out for my new one and off it went.
What email provider? There are other potential issues if it's gmail (or other provider that does 2FA or app specific passwords).
It is gmail.
I'll try some/all of the above because I think my wife is about to go on a kill crazy rampage!
Gmail SMTP server address: smtp.gmail.com
Gmail SMTP user name: Your full Gmail address (e.g. example@gmail.com)
Gmail SMTP password: Your Gmail password
Gmail SMTP port (TLS): 587
Gmail SMTP port (SSL): 465
[b]Gmail SMTP TLS/SSL required: yes[/b]
Gmail password won't work if it's set as an IMAP account rather than a "gmail" account and you have two factor turned on, you need to generate an app specific password.
