I'm allergic t...
[Closed] I'm allergic to my Fenix 3
 iolo
[#7007013]
For the last week or so I have a big red itchy patch where I wear my Fenix 3.
According to my pharmacist I am allergic to Nickel which is what the underside of my Fenix 3 is made from.
Has this happened to anyone else? Is there an easy fix? I don't really want to paint the underside with nail varnish if I can avoid it.
Posted : 18/04/2015 5:58 pm
Stick a bit of heli-tape on the back?
Posted : 18/04/2015 5:59 pm
I'm very surprised a watch as expensive as that uses nickel, which is a known allergen, instead of stainless steel, which even the cheapest Casio digital watches use. Are you sure it isn't just where the watch is a bit tight, and you're getting a sweat rash underneath? I have a cheap Bell & Ross knock-off, with the rubber/silicon type band, and my wrist got very red and itchy under the strap, to the extent I stopped wearing it, it was unbearable.
The watches I wear now have either leather or stainless mesh straps, and I don't have a problem, however I do wear a G-Shock occasionally which has a mod allowing a nylon NATO strap, and I can get an itchy red patch underneath that, despite it being nylon against my skin; I tend to have it fairly tight, it's not comfy if it's loose fitting.
Posted : 18/04/2015 6:12 pm
 iolo
It's definitely not too tight. I have no idea if it actually contains nickel but my pharmacist says it definitely looks like a nickel reaction. There's a central circle in a different metal on the back and the inflammation exactly matches that.
Posted : 18/04/2015 6:30 pm
 rob2
Not happened to me but just put a piece of insulating tape over it.
I like mine but it doesn't half bash my hand on rough decents, taken to wearing it over clothes.
Posted : 18/04/2015 6:38 pm
Sorry about the hijack, but how are you guys liking the F3 (apart from the rash!), recently got a F2 which I really like.
Now thinking about an F3.
Posted : 18/04/2015 7:31 pm
 iolo
It's great most of the time. It drops gps at times and sometimes the vibrate comes on constant. It needs hard resetting then it's fine for a bit.
Posted : 18/04/2015 7:34 pm
If I recall didn't Garmin have a bit of an issue with this sort of thing on their fitness bands?
Edit: Nope. That was [url= http://www.fitbit.com/forcesupport ]Fitbit[/url]. As you were.
Posted : 18/04/2015 8:32 pm
Stick it on a Nato strap, then there's two layers of nylon between your wrist and the back of the watch. I switched mine because I hate rubber straps with a passion, and the steel bracelet version seemed silly for sports purposes.
[img] ?raw=1[/img]
Strap came from [url= http://www.sectime.co.uk/26mm-desert-tan-nato-nylon-watch-strap-strong-heavy-duty-45-rings-pvd-p-4312.html?cPath=321_1466_2205 ]SecTime[/url], you need a 26mm one.
Posted : 19/04/2015 8:01 am
Unlikely that the watch is made from nickel. More likely it is made from stainless steel. Most common grade of stainless contains around 8% nickel. Pure nickel on its own would be too expensive and it's not particularly workable. Might be nickel plated though.
Posted : 19/04/2015 9:45 am
it's the nickel in the Stainless (and other items like buttons on jeans etc.) that does it.
for some reason I thought there was some strict EU limits on nickel content, and even Euro coins are low nickel, but can't find where I thought I read that.
mine was from a cheap watch with cheap stainless back when I was about 15. Have a permanent scar from that.
One reason I wear one of those cheap G10 watches, with a fabric strap.
Posted : 19/04/2015 10:23 am
