So, looking for a house, and if we can't find one with a garage, I will need a shed.
How much should I budget to have a decent size secure shed built? Nothing fancy. Needs to be big enough for 8 bikes and a workshop area.
Ballpark figures, obviously.
Cheers chaps,
Paul
Costing me 4.5K for a 12x17 shed in ireland - it may be slightly overbuilt and I suspect you can get things a lot cheaper in the UK.
8 bikes and workshop would be a tight fit in there though.
Cheers Saccades - I was thinking of asking the financial controller to put aside 5k, so my thought process looks to be about right.
[i]8 bikes and a workshop area.[/i]
That will need to be a fairly big shed so probably 10*8.
Been a while since I got a shed built but roughly £1500 to £2k.
£5k! That's going to be a pretty good shed.
I want a nice shed. 🙂
Buy a 20 x 8 shipping container ?
10x18 workshop here.
Think it was £2.5k for the shed but you'll need a shed base as well.
Loads of room for work tools, bikes and a maintenance area as well.
5k will be plenty for a bit of racking/storage/sound system/pimping!
Just had a 10x8 shed built with base, delivered and erected. Couple of extra shelves. Came to £746 (this is for gardening purposes)
Not big enough for 8 bikes though! I would say 3-4 bikes at a push and they would have to be smartly packed against the wall for you to have some sort of a workshop.
I think you actually need a bit more space than 10x8.
My local www.mansfieldshedsandfencingsupplies.co.uk/ Some guide prices on there.
Was very impressed with the quality.
We've recently had a 12x8 shed put up and I'd say getting eight bikes & workspace in there would be very tight and untimately quite annoying. Saccades is in the right ballpark with 12x17 IMO.
One of my sheds is 11x7. 5 bikes, some racking, bench over roller tool box, pretty tight TBH. I'd be looking at something 12x18 just so you have somewhere other than a bench top to work on.
Cheers chaps, liking all the suggestions.
Would there be any planning permission stuff involved?
Sheds are temporary installations so don't need planning.
Your's isn't unless there's a nuclear holocaust!
All depends if you are getting someone to build it for you or sourcing the timber yourself for them to build. You could plant the tree seed and wait if you want to do it cheaper still. 😉
Anything less then 15k and it's not a real shed! 😉
Also worth insulating with Celotex or the like - not cheap so budget for this too.
And for 8 bikes and a workshop area I'd reckon on 4m x 4m, but with a pitch roof for extra storage space.
This kinda thing, although tbh I reckon a brick built 'garage' would be far better/nicer.
http://www.gardenbuildingsdirect.co.uk/Wooden-Sheds/The-BillyOh-5000-Range/18374
This looks fantastic for the money.
[url= http://www.ebay.co.uk/itm/4-65m-ISO-Workshop-Container-/301647037569?pt=LH_DefaultDomain_3&hash=item463b908481 ]http://www.ebay.co.uk/itm/4-65m-ISO-Workshop-Container-/301647037569?pt=LH_DefaultDomain_3&hash=item463b908481[/url]
You could clad it easy enough to make it more garden friendly if needs be.
Just been in a similar situation but could not part with the ££££ for a shed...so I built one myself
12 x 10 with windows.
After shopping around the local timber merchants, I bought 20mm treated redwood shiplap,18mm plywood flooring,11mm OSB and heavy duty 38kg mineral felt for the roof.I got some free recycled 4x2's for the frame.Complete shed cost was £370 and took a weekend to build
The shed is bomb proof!
16 x 10 fully tanalised, council slab base, insulated, ply lined. £2k
or for something different check out a nissen hut kit from GT evans newtown,
http://www.gtevans.co.uk/nissen.htm
I have a 16x10 with an extra 1m deep rear veranda for outside storage. Should be about right for what you want as a minimum.
As I have said before I would build my next out of 200x47mm T&G dungwall. Will need a chainsaw to break through it. Agri store do it on offer for £15 (inc. VAT) for 4.7m or £20 normally or £28 for 6.1m - could make a nice 20x10 shed very easily from that.
Double skinned, insulated roof with steel box section on top. Find a source of cheap tempered glass for the windows (eg ikea shelves) and make a double wall window with glass on the outside with reflective film and polycarbonate on the inside (glass won't scratch like PC).
Yours sounds like just what I want AndyL 🙂
Andy- wanna come build my shed for me?
Sounds perfect!
