After being let down by our conservatory company i am trying to make a replacement part for the door hinge. The problem is I need to buy a length of aluminium bar with the same profile as the picture below. Any ideas where I might find such a bar?
Local engineers should be able to knock you one of those us pretty easily
how long do you need it ? If not too long any engineering comp with a cnc machine could knock that up in minutes.
"I want to keep it!"
(IGMC)
You could try some of the profile manufacturers like Gooding or Alco but they probably won't have it and will have a minimum order. Tricky if you just need a little bit.
I need about a metre length of it. Anyone recommend me an engineering company that does little jobs in the Surrey area?
