HELP. Laptop screen...
[Closed] HELP. Laptop screen has gone large font and everything has doubled in size WHY.
[#2261793]
I turned on my Laptop this morning and my screen has gone all large, WHY, HAVE I PRESSED SOMETHING?
How do I change back to standard font/screen size.
Posted : 07/12/2010 2:14 pm
Try holding down CTRL and rolling your mouse scroller back.
If you have a mouse that is.
Posted : 07/12/2010 2:16 pm
No it's not that, it's at the top and bottom of the screen.
I mean the start box has doubled in size and all the box's at the top of the screen too.
Posted : 07/12/2010 2:23 pm
Follow this link:
Control Panel\All Control Panel Items\Display
And click on small, medium or large
Posted : 07/12/2010 2:28 pm
My daughter does this nicely. You can be scrolling through some webpage and she decides she wants to press a button or two.. well ctrl is closest to her so before you know it everything's H U G E.
Posted : 07/12/2010 2:31 pm
molegrips< how did you revert back to normal size screen
Posted : 07/12/2010 2:42 pm
Hold down ctrl and scroll the other way! Using the mouse wheel or the scrolly part of your touchpad.
Posted : 07/12/2010 2:52 pm
yes that works but not for the whole screen.
My "START" and icons at both top and bottom of the whole screen are HUGE and by doing what you said only the print in the screen reduces.
Posted : 07/12/2010 3:01 pm
Oh.
What version of Windows is it?
Posted : 07/12/2010 3:31 pm
Try ctrl and F2 (or F3 can't remember which)
Posted : 07/12/2010 3:33 pm
I'm running Windows XP
Posted : 07/12/2010 3:34 pm
Sounds like you've changed the screen resolution.
Right click on the desktop -> properties -> settings -> screen resolution. Slide the slider to the right
EDIT: If this 'just happened', you might find you can't slide the slider, in which case you'll need to re-install a driver. But try it first
Posted : 07/12/2010 3:44 pm
Could be Windows Magnifier. ****in useless thing - if you hold the Win key and '-' it may rectify itself.
(s**** - rectify)
Posted : 07/12/2010 3:45 pm
Guys all sorted thanks.
Posted : 08/12/2010 9:23 am
Were you just sitting too close to the screen?
Posted : 08/12/2010 11:35 am
Not if you are partially sighted!
Posted : 08/12/2010 12:07 pm
