Funny that this pops up today:
[url= http://www.opusenergyblog.com/floating-tidal-turbine-off-orkney-islands-breaks-generation-records/ ]floating-tidal-turbine-off-orkney-islands-breaks-generation-records[/url]
Seems like an interesting solution, being moveable, scaleable, and does not require enormous on site infrastructure. In fact i suspect getting the 'lecy cables to it will be the biggest cost!
(as an aside, work out how much torque 2MW is at 16rpm!! oof! 😯 )
Interconnectorection to Norway is a massive benefit to U.K. and I'm surprised the UK govt hasn't pushed this through faster
The current Norwegian wholesale price is 50% that of the UK
There is a massive energy surplus in the Nordics
Norwegian hydro is flexible and can be used to balance the UK system
I don't see a massive appetite in Norway to build more large scale hydro (in fact I think has been opposed) but they could easily add new penstocks and turbines to existing reservoirs (including when they are repowering old facilities) if there was a need. However there is probably enough spare capacity for at least 2 cables to the UK (24twh and about the same as Hinkley PC) and I know which one I'd go for.
If there's one thing you should have realised by now it's that the government doesn't necessarily do what's best. I think there were some issues on the other side too, but at least one of the proposed Norwegian ones is progressing.
. http://euanmearns.com/50-re-in-the-uk-the-ugly-facts/#more-18511
In case you hadn't realised, this guy wears the same rose tinted specs as Trump and is just a stuck record anti-renwables campaigner dressing up the same weary message with some graphs and numbers.
So which of his numbers are wrong then?
