frustrated thicko w...
[Closed] frustrated thicko with monitor cable question
[#10246787]
My google-fu is weak
My docking station has a display port output.  My monitor has DVI and HDMI inputs (but no display port)
My assumption that a display port to hdmi, or display port to DVI cable would make it all work seems to be flawed - tried both, neither works.  HDMI out from the laptop works, but seems to defeat the purpose of the docking station!
Is my dock broken, have I got the wrong sort of cable, or have I missed a setting somewhere?
Lenovo Onelink+ dock, Benq GL2460, Thinkpad 13 / Win 10 if any of that is important
Posted : 27/09/2018 1:37 pm
checking out via the screen options in win 10?
Docking software up to date?
Posted : 27/09/2018 1:41 pm
Most likely the dock.
How do you connect to the doc - by USB ?  There may be a driver issue (i.e. not installed)   A DVI to HDM should work (that's what my some uses, a mix of HDMI to HDMI, DVI to HDMI etc as he has 3 monitors, so uses most of the outputs on his graphics card.
Posted : 27/09/2018 1:44 pm
You have 'toggled' the screen output ?
Check display settings too - use duplicate first to check the lot is working
Posted : 27/09/2018 1:45 pm
you lot are quick, thanks
Dock has it's own special connector (a onelink port according to lenovo).  Dock driver and windows up to date.
Attempting to duplicate output gives a 'no display detected' message.
Posted : 27/09/2018 2:01 pm
I think thattthr cables only work one way, DP monitor, DVI dock. May be wrong, can't remember which way it is.
Posted : 27/09/2018 2:38 pm
I think thattthr cables only work one way, DP monitor, DVI dock. May be wrong, can’t remember which way it is.
Going from a DP port on the laptop to a HDMI monitor should work, it's going from HDMI to not-HDMI that can be tricksy.
How do you connect to the doc – by USB ?  There may be a driver issue (i.e. not installed)
The OneLink uses a proprietary connector I believe.  If you're connecting it via USB, that's why it doesn't work.  You need a driver also.
Driver and setup guide here:
https://support.lenovo.com/us/en/solutions/ACC100252
EDIT: sorry, I missed the reply where you've said this is all fine.  Hmm.  Get on to Lenovo support maybe?  It could just be broken?
Posted : 27/09/2018 3:00 pm
have you powered the dock?
do any ports in the dock work (usb)?
Posted : 27/09/2018 5:11 pm
Eg some lenovo docks have a bigger psu than the normal laptop one to power more stuff
Posted : 27/09/2018 5:12 pm
Further thanks to all.
Since writing I have double checked firmware and drivers - Cougar's link was where I think I did this when I first set up the dock, and both said 'you are already up to date'
Power - good point DaveP.  90W supply (came with dock), vs 40W on the laptop - swapped and got an error message about low power.  USB and network all behaving as expected, just the display ports (two of them: neither works).
I did have a DP-HDMI, and swapped if for DP-DVI (thinking it was the cable).  Same symptoms (display not detected).  The dock has only DP outs.  Monitor works with HDMI-HDMI.  I don't have another DP source to test with unfortunately.
It's not one of those directional cable things is it?  I thought that was just for HiFi buffs?
Lenovo forum suggests drivers, but I think I've addressed that.  Have logged a ticket.
Posted : 27/09/2018 6:52 pm
