Expensive things th...
[Closed] Expensive things that are a bit rubbish
doesn't get much more expensive or much more useless than this
Nukes stopped the cold war from ever going hot, if there had been no nukes, Russian T-55's would have stormed accross Europe a long time ago.
Nuclear war makes large scale industrial war between developed nations a losing proposition for both sides, without them, one side will always believe that they have a chance of gaining something from war.
Posted : 19/05/2014 11:03 am
 Solo
Yeah, new builds. Shyte !
Ever increasing prices, still shonky planning, workmanship and finishing.
Posted : 19/05/2014 11:04 am
MidlandTrailquestsGraham - Member
MTB Marathons.
£35 to ride on Public Rights of Way?
Signs, maps, prizes, organisation, marshalls, first aid cover?
Posted : 19/05/2014 11:12 am
 Leku
solar panels being a requirement for all new builds
These would CSH level 3 dwellings built under May 09 guidance. Now most are built using fabric first approach and thus no renewables.
Posted : 19/05/2014 11:17 am
In order to do that you need more land, which makes your house very much more expensive. Or you build three storey houses, like mine
IIRC three storeys makes for lower heating cost compared to the same floor space on two storeys.
Guess you lose some floor space with the extra stairs.
Posted : 19/05/2014 11:22 am
@Harry, our Dyson does that (cuts out all the time) and its because the battery is a bit loose. Slam it with your hand, so that the battery goes completely back in, and its perfect again.
It's a bit annoying but I just like to pretend I'm slapping in another magazine before taking down some more mofos*
*raisins, toast crumbs, rice crispies etc
Posted : 19/05/2014 11:23 am
Agree with OP re Dyson's.
Poor build quality and about as much suction as a 200 year old emphysemic tortoise using a straw with holes in – utter gash. Well ours is anyway.
Posted : 19/05/2014 11:24 am
IT Departments!
*ducks*
Posted : 19/05/2014 11:27 am
Meaning what?
I think all houses should be three storeys. 50% more floor space and no downside. Our house takes up less floor space than the normal 3 bed semis in neighbouring developments, but has two big bedrooms and one good sized, rather than two small ish and one unusable box room. Has a big living room too.
anything with crank brothers written on it
Posted : 19/05/2014 11:35 am
Pretty much all London property. Until the bubble bursts of course
Posted : 19/05/2014 11:36 am
Dyson's how is no bad actually a good design feature, just means the dust escapes when you empty it. Apart from the fact their build quality is completely variable.
Audi A3, not as good as the VW Golf despite essentially being the same car for more cash.
Merino wool baselayers.
Austin Reed shirts.
Posted : 19/05/2014 11:37 am
Only on STW do you get willy waving about [i]toasters[/i]!
Posted : 19/05/2014 11:47 am
Insulate beyond building regs, focus on airtightness, effective windows and doors.
Code for Sustainable Homes is a well intentioned but poorly designed standard that creates some perverse incentives. There are too many 'points' for renewables so they're not a requirement but it's easier/cheaper (and requires fewer changes to the way they build) for housebuilders to just stick some solar panels on the roof.
Likewise the EPC energy performance rating. As I understand impossible to get an A rating without renewables, even if you've no requirement for heating (completely passive).
Posted : 19/05/2014 11:50 am
Encouraging then - our neighbours have put their house on the market and it's been given a B rating.
Do they test this or look at your bills or something?
Posted : 19/05/2014 11:58 am
Yeah, considering the number of riders you see on these events, compared to the number of riders you see on exactly the same PRoWs on any other day of the year, I guess that list must be an important requirement for a lot of people.
For some of us though, it's just £35 to ride on bridleways.
Same goes for sportives and public roads.
Posted : 19/05/2014 12:07 pm
surroundedbyhills - Member
IT Departments!
*ducks*
Careful now!
ps - I really like my not that old Dyson and Dualit products.
Posted : 19/05/2014 12:13 pm
Parliamentary democracy
Paper exercise based on what is meant to be installed and a lot of assumptions. Takes no account of how well it's done (eg is the insulation tightly butted and taped or just thown in?) or actual energy use.
Posted : 19/05/2014 12:19 pm
HS2 it's gonna cost lots and still be delayed and late.
SammyC - Member
Thanks, I'll try that.
Lock n' Load!
Posted : 19/05/2014 12:39 pm
 Solo
[i]Thanks, I'll try that.
Lock n' Load![/i]
I'd suggest NOT slamming the thing with your fist, but slightly shimming the gap between battery and its retainer / lid, whatever.
Posted : 19/05/2014 1:00 pm
Cars. Expensive and rubbish. I resent spending thousands of pounds on something I have to drive to get to boring meetings, usually through interminable traffic jams and roadworks, surrounded by thousands of rude, selfish idiots.
I realise that this is something of a minority viewpoint, however, and nearly everyone else in the UK thinks spending vast chunks of their hard-earned on something that makes them angry and fat is just brilliant. Ho hum.
Posted : 19/05/2014 1:05 pm
Cars aren't rubbish, it's your lifestyle that's rubbish.
Cars, as objects, are absolutely incredible things, and given how much work has gone into each one it's amazing how cheap thye are. You just listed a load of problems with modern life, not problems with cars.
PS cars don't make you angry and fat - you make yourself angry and fat. Cycling is just one way to make yourself thin and happy, there are others.
Posted : 19/05/2014 1:10 pm
if you read too much molgrips you'll become angry and fat
Posted : 19/05/2014 1:26 pm
Jamies Restarants.
Overpriced grilled veg and pasta 🙄
Posted : 19/05/2014 1:44 pm
Modern Life is Rubbish!
Posted : 19/05/2014 1:53 pm
not many credible alternatives around, though?
Buy an older one, spend less money. You can buy some decent old cars for very little money.
Posted : 19/05/2014 1:57 pm
Women! Just when you think you've found a reliable and economical version it starts producing children ffs!
Posted : 19/05/2014 2:24 pm
17 year old Dyson which still works just fine here - it was certainly a step up on anything else available at the time.
Posted : 19/05/2014 2:55 pm
Either you had something to do with that or you have other problems.
Or misquoting from above
Posted : 19/05/2014 2:57 pm
loving your work
Posted : 19/05/2014 2:59 pm
Is there not a meme for how long it takes an internet discussion to start dissing Dyson's? if not I claim my £5 voucher and name rights - Disdyson law.
I'm in the pro dyson lobby FWIW over 15yrs and counting, and it's Green too 🙂
Posted : 19/05/2014 3:21 pm
No views on Dysons as never had one, but he does come across as a rather annoying shouty angry man (Dyson).
Posted : 19/05/2014 5:22 pm
Our dyson dc01 has finally died after 14 years can't fault that.
As for rubbish landrover defender or more specifically post tdi ones
Posted : 19/05/2014 9:45 pm
I like it when people say "I can't understand how your <product X> isn't reliable, mine is 50 years old and never misses a beat", as if a product can't change in 50 years! Might as well say "I own a completely different product and it's reliable, why isn't yours?"
Posted : 19/05/2014 9:47 pm
Miele. Standards dropped in certainly 20 years. Never again.
Posted : 19/05/2014 9:52 pm
Don't say Miele I've just treated myself
Posted : 19/05/2014 9:57 pm
Fake boobs
And semi-trolling, but, Jones bikes. Still don't get the one size fits all thing. They are expensive and rubbish until I've ridden one 😛
Posted : 19/05/2014 10:17 pm
OK, I'll bite, just for a second. Yes, any individual car can be held up as well designed and fit for purpose, but... Modern, western life has been shaped at a fundamental level by the motor car. Indeed it is intrinsic to some of the worst aspects of our modern life. If the motor car didn't exist, life would be very different (not necessarily worse). So saying that my problem is with modern life is disingenuous, because modern life is how it is partly because of cars. And many of the things that I hate most about modern life are hateful precisely because of the nature of the car, which encourages the worst aspects of human nature (selfishness, apathy, acquisitiveness, aggression, indifference). So, by and large, I stand by my assessment: cars are shit.
But like I said before, I don't expect anyone to agree with me.
Posted : 19/05/2014 10:36 pm
That's absolutely true, but it's not the fault of the car - it's the fault of us who use them. We did not realise what we were doing to our lives. People have always needed to move around. The car is just better at it than many systems. A lot of things have been made possible because of the car.
You make a good point, but I believe that people have always had those attributes, and car usage behaviour is simply another symptom. Technology gives us freedoms and enables us to express ourselves, for better or worse. But it's not the fault of the technology, on the whole.
Cars are neutral to me. There are choked angry commutes, but there are also family road trips and glorious drives through the countryside. There are angry commutes by car and angry commutes by train. 100 years ago we'd have been commuting on foot, and probably having a nice stroll, but we'd have been walking the same streets our whole lives to the same factory and doing the same shit. And the town would have been smoky and dirty because the factory was right in the middle of it.
Posted : 19/05/2014 10:43 pm
Plus One for Dre beats , they are nothing but a cheap fashion Item that sound as good as apple's earphones.
Posted : 19/05/2014 10:47 pm
barbours.
Posted : 20/05/2014 12:09 am
 gazc
the south east - expensive to live there, pretty rubbish really (unless you are minted)
Posted : 20/05/2014 9:22 am
I agree with your post.
Posted : 20/05/2014 10:03 am
Page 3 / 4
