engine oil stop lea...
[Closed] engine oil stop leak wynns
[#10515902]
any used it ?
Yes I know the fix is to find the drip - but on a 4.2 V8 no chance !!!!
My mechanic and Audi forums seem to suggest it can/does work...
thoughts
Posted : 03/03/2019 12:18 pm
Yes I've used it on Landrover engines (that in itself should say something) and it does work quite well. It also works on the valve stem seals if the engine blows blue smoke when cold. Obviously it does depend on how bad the seals are but it's worth a go being so cheap and easy compared to the job of seal replacement.
Posted : 03/03/2019 1:29 pm
 nofx
I used it in my Subaru legacy. It worked a treat. No adverse effects ,it just bunged up the leaks 😊
Posted : 03/03/2019 1:52 pm
