electric underfloor...
electric underfloor heating controller (Wiser electrical heat switch)
[#13403848]
Anyone know about these? Currently have dumb HeatMat controllers. Looks like it'll be a straight swap to the Wiser smart controller as connections all the same (supply, load, sensor). There is a decent offer on the Wiser web shop at the moment (40% off) so tempted! Have the rest of the Wiser system for gas central heating already.
Posted : 02/10/2024 1:22 pm
Fitted them before to various underfloor heating mats, as you say it should be a straight swap, just make sure it has the capacity to switch the intended load current.
Posted : 02/10/2024 1:43 pm
Thanks. The Wiser switch is rated to 16A which is the same as the HeatMat thermostat so assume it'll be ok!
Posted : 02/10/2024 1:49 pm
I use WarmUp wifi thermostats - you can control them from your phone and using IFTTT (I've set up some nerdy stuff with a pi to switch the underfloor on and off depending on the cost of electricity on Octopus Agile.
Pretty sure they all have the same connections and are very interchangeable.
Posted : 02/10/2024 2:26 pm
