Struggling with dust on the sensor on my d80. I have a blower, tried swabs (expensive over the long term). So fancied trying an Arctic butterfly as they are so compact I'd be able to take it with me on cycletours.
Questions- are they worth the money? how effective are they? If my sensor is clean (no smudges) can just use the arctic butterfly?
And any other views....
I havent tried one of those. I did try an airbrush in a can from a pc shop.
Don't do it! I caused blemishes across the mirror and a send back to Canon ...so be a bit careful with what you try.
I bought one a couple of years ago and used it once.The brush vibrates and the problem I had was it managed to pick up a load of grease from around the mirror,this grease was then spread beautifully across the sensor ! Proper disaster.Never had the courage to use it again.I now use [url= http://www.dust-aid.com/?gclid=COzxo5jKh6UCFQ_-2AodsC11Pw ]this[/url]which you can get [url= http://www.cameraclean.co.uk/index.php ]here[/url]
No problems and simple to use.
Great name though-Arctic Butterfly !
I use Eclipse fluid and pec pads. My cameras get a battering at weddings and I change lenses a [u]lot[/u]. The fluid and pads system was the first I tried. It worked and I've stuck with it ever since. It's pretty cheap too, which helps.
Thought about the butterfly thing along with sensor pen and mini vac gadget
Figured if it was fluid and pads for the shops and pro's that was the right way to go
Does the job and can't ask for more than that
