Dirtwork adaptation...
[Closed] Dirtwork adaptation?
 Sam
[#1127145]
I'm in the process of planning a van camper conversion and one of the things I'd like to have would be a pressure washer in the van. I'll be running 12V electrics and am thinking of trying to hack a dritworker apart and attach it to a larger resevoir. Wire it in to and you've got on-board pressure washer with lots of water (one of the things I don't like about dirtworkers being about the need to refill them. I was thinking a couple of lengths of large dia pvc pipe to act as the tank. Any reason this wouldn't work?
Posted : 14/12/2009 12:55 am
That'll work...the advantage of the pipe is you can probably attach them under the sills of the van rather than take up internal space. Quite a nice idea actually, might look into that for my van rather than spend £100's on a custom made underslung tank 🙂
Any pics of the van?
Posted : 14/12/2009 7:29 am
No reason why it won't work and no need to get a dirtworker to do it, just buy a 12v water pump and a spray gun. I've seen pics of a guy who built his own washer this way with a 25l plus water container.
Posted : 14/12/2009 8:39 am
yep, look out whale pumps, they're about £25 for a decent one, it'll kick out a reasonable amount of pressure with a normal garden hose attachment.
Look at caravan suppliers or boat supplies.
Posted : 14/12/2009 11:12 am
[i]No reason why it won't work and no need to get a dirtworker to do it, just buy a 12v water pump and a spray gun. I've seen pics of a guy who built his own washer this way with a 25l plus water container. [/i]
I think that was me 🙂 But to be honest, the dirtworker is better as it is more of a jetwash, rather than a low pressure hose. The one I adapted was a 12v Inovex Smartwash from Halfords, dumped the open topped water container and replaced with a 25L container. Still in use, but for hosing off sweaty/muddy horses at competitions, rather than bikes 🙂
Posted : 14/12/2009 8:08 pm
 IA
I use a 12v pump (from a car shower) then a hoselock connector on the end, and a brose attachment (brush-hose = brose) doesn't need high pressure, and cos of the brush attachment you get the bikes properly clean, rather than just jetwash-clean. Also water goes further, 15L will do 3 filthy bikes.
Posted : 14/12/2009 8:14 pm
