Dimming low voltage...
[Closed] Dimming low voltage halogens
[#494893]
I've got some low voltage halogen underlights in the new kitchen and I'd quite like to put a dimmer on them. Their wired into the main light switch so that isn't an issue.
Having done a bit of research all I've ended up with is a load of conflicting statements about the need for special low-voltage dimmers.
Anyone got a standard dimmer wired into a set of low voltage halogens - any issues like buzzing at the switch, bulb failure, etc.
Posted : 23/04/2009 8:43 am
I have low-voltage downlighters with a dimmer. Not had any problems/noise at all.
But not all low voltage lights are dimmer compatible so you had best check with your particular lights.
Posted : 23/04/2009 8:46 am
I did this in our pevious place, worked fine for 6 years.
Posted : 23/04/2009 8:49 am
You can dim low voltage halogen lamps off a rotary dimmer with no problem 🙂 If you dim the lamps by about 10% you can double the lamp life
Posted : 23/04/2009 9:03 am
fine here
Posted : 23/04/2009 9:13 am
if the transformer is a standard (wound transformer) type then it'll be fine. some electronically controlled transformers are non-inductive loads and will kill a standard wall dimmer
Posted : 23/04/2009 9:19 am
