Dilute bleach and b...
[Closed] Dilute bleach and bathing
[#7786663]
Would you suffer any I'll effects from getting in a bath of what one could only assume is really diluted bleach.
For example if someone had cleaned the bathroom but left a few inches in the bath before running it?
Posted : 23/04/2016 7:01 pm
Skin complaints most likely, even totally watered down multi surface shit will dry you out.
Empty it, rinse and repeat (minus bleach)
Posted : 23/04/2016 7:02 pm
Do you really need to ask...!?
Posted : 23/04/2016 7:04 pm
It feels refreshingly clean..... 😳
Posted : 23/04/2016 7:05 pm
Your downstairs bits would know about it before the rest of your body 😯
have another bath (without bleach and soap) and soak
Posted : 23/04/2016 7:07 pm
If it's very diluted I can't see why it would be a problem - most people drink diluted chlorine from their tap water without any ill effects.
EDIT : I'm assuming that "a few inches" is something of an exaggeration as it would take many bottles of bleach for it to be several inches deep in a bath.
Posted : 23/04/2016 7:30 pm
I have known it recommended for certain skin infections.. Can only assume at the lowest of levels though rather than pube bleaching
Posted : 23/04/2016 7:31 pm
Just shower it off. Like after swimming.
Posted : 23/04/2016 7:41 pm
Once you're dry there won't be any bleach on you.
Posted : 23/04/2016 7:46 pm
Just don't overdo it
Posted : 23/04/2016 7:49 pm
I think a more likely result might be this :
Posted : 23/04/2016 7:52 pm
Looking at the PH table on the attached you either need to be very sick on yourself or go out to the car and pour battery acid over yourself
http://www.bbc.co.uk/schools/gcsebitesize/science/add_gateway_pre_2011/chemical/acidsrev1.shtml
Posted : 23/04/2016 7:55 pm
@ernielynch " Skin rejuvenation" WTF??
Posted : 23/04/2016 8:00 pm
Try a little bit in a beaker first.
Posted : 23/04/2016 8:02 pm
Posted : 23/04/2016 8:13 pm
Looks like he's just dipped it in the beaker.
Posted : 23/04/2016 8:19 pm
Looks like he's just sipped out of it.
Posted : 23/04/2016 8:20 pm
Ah yes, the old dip'n sip.
Posted : 23/04/2016 8:23 pm
