So,
the garden room I am currently building lends itself to being a good spot for a sun terrace - 7 m* 3m - I have built the frame in a combination of 3x2" and 6x2" c24 grade so it has plenty of load capacity- I am erring towards and EPDM roof with a simple framed wooden deck laid on top - anyone got experience of this and has any tips?
I put it on the shed roof ...
Super easy and will probably outlive me. Measure 3x cut once.... leave loads of overlap and obviously some slope to drain.
I need to redo the garage/utility room roof and will be going for EPDM.
if you're building on top of the shed roof, I think you'll need planning. raised outdoor flooring is generally restricted due to being a bit cr*p for neighbours. Might not be the case for you mind.
EPDM is great, a bit pricy but really good stuff. I put some 1.5mm on the roof of the cabin which is underneath a big oak. I have seen branches drop 30 or 40 feet land end on and just bounce off without damage. Helps having big rafters and 18mm ply underneath I guess but no tears, snags or issues.
Turns out is was OSB, not ply but it worked.
Step 1 Lay out the rubber to un crease
[img]
[/img]
Step 2 Roll it back and glue it to the roof
[img]
[/img]
Step three brush it down against the glue to remove as many creases and bubbles as you can
[img]
[/img]
EDPM rested on the roof one day and fully fitted the next
We have something similar as part of our house. Single ply flat roof membrane. Terrace frame just sits on top. watch out for any point loads or potential movement damaging the membrane - we cut extra bits of membrane to sit under the load bearing feet we have, and we made them height adjustable. But our frame is steel.
Also, consider whether you need to access to clean the membrane every now and then. Or fish out the bits of Lego that have fallen between the decking boards.
Pretty sure 5lab is right.... Planning required and I'd imagine could be knocked back if you have neighbours.
A more stealthy way would simply to put these tiles down
https://www.ecotileflooring.com/product/lifestyle-outdoor-flooring/
We've had them on a balcony for about 10 years and they still look like new. Light, strong and allow the rain to sit below the surface so even if you have puddles it shouldn't affect its use (unless you have a very badly laid roof).
Fitted in minutes as they click together and easily lifted if required. Never had any movement even with the strongest of storms in an exposed coastal location.
Don't forget the falling off issue if you don't have balustrades.
Cheers all,
some good ideas - think the EPDM is definite the way to go, and liking those roof tile things @sharkbait. next job - start emailing council about permission - shouldn't be too big a deal in our place I reckon......
Don’t forget the falling off issue if you don’t have balustrades.
Even if you don't need planning(don't see why you wouldn't) due to height building standards apply.
