Central Heating Boi...
[Closed] Central Heating Boiler
[#5982521]
Looks like my PowerMax 155x boiler has finally given up the ghost which is not a bad thing as it's bloody awful.
My question is what should I replace it with??
Any advice would be greatfully recieved
ta
Pete
Posted : 22/02/2014 5:13 pm
Not the easiest question to answer really without seeing the current set up I would suggest a nice wall hung combi from the likes of Worcester Bosch or Vaillant.Alternatively you could have a Boiler/Megaflo package,it depends on your hot water requirements and budget.
Posted : 22/02/2014 5:53 pm
OK thanks well we have no real deamnd over and above a normal household for ho****er bath and ensuite shower
Budget circe £800-900 I suppose looking online
Posted : 22/02/2014 6:07 pm
Baxi have 7 and 10 year guarantees on some combis, just had one fitted, seems fine so far(5 days old, and never had to do a thing to it!).
Posted : 22/02/2014 6:21 pm
cool mate who's a plumber recommended a Baxi so may got that way unless the dreadful PowerMax can be fixed cheaply, its a right pain noisy and unrealiable
Posted : 22/02/2014 7:08 pm
Power as will have been fitted due to the fact it uses twin flues, and long flue runs, that may ultimately be your deciding factor.
I'm assuming you live in a flat?
Posted : 22/02/2014 7:31 pm
Aren't there building regs issues replacing a boiler with a long flue run? My previous landlord was whinging about the cost of installing inspection hatches in every room the flue ran through.
Posted : 22/02/2014 7:34 pm
no we live in a detached house these were fitted to loads of house on my estate as builder got them cheap seemingly from Potterton don't google them it doesn't make pretty reading
Posted : 22/02/2014 9:36 pm
I've just replaced a potterton conventional boiler with a Worcester Bosch combi the same as I did at a previous house and so far it's been excellent. I went with the CDI Compact.
Yet to get a bill to notice the difference financially.
Posted : 22/02/2014 9:41 pm
you want a boiler fitting for 800 quid.. good luck..
get a worcester 28si hook up a magnaflow and they WILL honour thier 5 year warranty..
Posted : 22/02/2014 9:44 pm
Seeing as you have said central heating boiler rather than combi, it would suggest you need a system boiler.
I would definitely recommend a Worcester, especially if you get an installer who is able to offer a seven year guarantee (think you have to install the Worcester filter now to qualify)
I am a sparky and wire 2-3 boilers a week for a local firm and being honest i haven't know a system boiler to give any trouble.
Admittedly they are basic but seem very reliable.
If you want a combi boiler, again i would definitely recommend a Worcester still, i can't really compare to other brands but the customer service/guarantee has been second to none and that is the service i have received for my own boiler, not just customers.
Either way, i think your £800-900 budget is a bit optimistic for a quality installer.
Posted : 22/02/2014 10:13 pm
no sorry the £800 was just for the boiler appreciate I'll have to pay my mate his daily rate
Posted : 22/02/2014 10:32 pm
800 quid will get you a BaxiPotterMain or an ideal logic. Don't even consider anything else at that budget, spend a little more and you're into Worcester/Valiant and Veismann
Posted : 23/02/2014 11:15 am
