Carrying a laptop o...
[Closed] Carrying a laptop on your bike
[#11250099]
I have used a backpack for the last couple of summers but im fed up of how sweaty it makes my back. How are messenger bags? Do they swing around a lot? Any other options (not on bike as I tend to ride different bikes) Commute is only 15 minutes.
Posted : 15/06/2020 4:56 pm
I found any bag that made contact with me sweaty (I run quite hot), the messenger bag I used had a secondary strap to stop cross body swinging.
I moved to a pannier, ruined a bunch of physical disks (some of the route was a bit off-roadish), ssd worked, now I don't take a laptop home if I don't have to and for the last few months have been all based from home.
Posted : 15/06/2020 5:02 pm
Probably sweatier than an well designed backpack - just a different shaped sweat patch. A backpack with good structure will give you a decent bit of ventilation  - messenger bags are structureless and clingier and also tend to be strapped quite tightly to keep them high up your back.
Backpacks like the Deuter Airlight have more of a rigid structure that stands off your back more (I've got an ancient Bergaus that has the same sort of design to it) . Its an open mesh rather than padding on the  bag thats in contact with your back so you have more airflow. You need the clothes you're wearing to be quite wicking too otherwise the mesh is just pressing sweaty clothes to your back but at least the bag itself isn't insulating you. Because the bags have a pretty rigid structure you need to get one thats a good length for you as they're not very forgiving fit wise.
Posted : 15/06/2020 5:03 pm
which one?
Posted : 15/06/2020 5:09 pm
which one?
Most Messanger bags do don't they? - its sort of what makes them a messenger bag rather than a satchel.
I've got a Trakke Mule - which is a huge (discontinued) messenger bag with a stabilising strap - their smaller ones have one two. But if sweaty is your problem a messenger bag isn't the solution. I use mine for pretty much anything but cycling - only use it on the bike for really ungainly loads - the last one being laptop, data projector, and A3 folio and a folding table to stand it all on for a presentation / interview.
Posted : 15/06/2020 5:14 pm
I have a Howies one that has a secondary strap and didn't move around at all. Miles better than a backpack as the weight sits lower. I don't think they do them anymore, which is a shame as the thing is still going strong after years of use. They're a quality bit of kit
Posted : 15/06/2020 5:18 pm
which one?
Something I have in common with binners! It was the Howies chevron bag, years old and still going strong but not been on sale for a very long time. Also had a Crumpler with no padding which wasn't great for bike use at all.
Posted : 15/06/2020 6:10 pm
I’ve used backpacks, messenger bags and panniers and by a LONG way, panniers are the way to go.
Posted : 15/06/2020 8:30 pm
