Well, I sent off to Venhill for a custom made hose (£32 delivered, bargain) and it was delivered today.
I just had the time to chuck it all randomly together and bleed, and, on a swift basic test, it seems to be fixed.
So it was the hose. I was right. (and that's TWICE I've been right today, a record I think!)
Which was my first thought, before Modern Vespa forum led me to replace the master cylinder (£45) and STW led me to replace the calliper (£38)
I'm not annoyed. Really I'm not.
But by fek that's the last time I listen to anybody else with anything mechanical! 😈
(I'm gonna pull the old hose apart and have a look inside. The old calliper and M/cyl are OK and I'll sell them on.)
Well, you wouldn't listen to me and TJ
TJ is correct, old fluid will only give you mushyness when you overheat it. [i]I suggest you've either bled it wrong or your braided hose has a problem[/i]. Weepy seals in either caliper or master cyl will be identifiable by a creep test - get a fairly strong elastic to hold the brake on, leave it a day or two and see if it's at the bar when you get back. If it is you have a leak, but it's unlikely to make it mushy.
Fair point CK, I'd not re-read the whole thread again and missed that, my mistake. 🙂
Damn, now I mentioned it on the other thread I look like a glory seeking arse. Self publicity fail.
