borked car power st...
[Closed] borked car power steering advice
[#3379534]
if a car's power steering packs in will it do any hard driving it temporarily?
Posted : 22/11/2011 6:52 pm
What Car ?
Posted : 22/11/2011 7:01 pm
Any hard? 🙂
Hare?
Hareem?
Hark?
(the herald angels sing)
Farm?
Harp?
(we have come because we heard about the...)
Posted : 22/11/2011 7:07 pm
Is is hydraulic? Any hideous noises? The pump might not like it if there is no fluid. If it is electric such as a corsa then I expect it will be fine
Posted : 22/11/2011 7:08 pm
fluid level is fine, the fuse is fine, guess it's some electrical stuff, need to drive 45 miles to airport in the morning, and back next week.
40DD - 'hard' should have said 'flange'
Posted : 22/11/2011 7:13 pm
 5lab
is it just the belt thats snapped? if so, no damage at all - however check if there are other ancilleries on there (like the alternator) that may make things more tricky
Posted : 22/11/2011 7:14 pm
have you tried driving it with the system not working - I really can't turn the wheel on my megane when the ignition's off.
Posted : 22/11/2011 7:15 pm
It 'seems' OK, just a bit hard to turn!!
Posted : 22/11/2011 7:18 pm
It'll be fine to drive without the power steering operating, just going to have heavy steering.
Posted : 22/11/2011 7:22 pm
With the ignition off, the steering lock will be engaged.
You're right though; with the ignition on and the engine off, the wheel in my Mondeo is near impossible to turn. I wouldn't like to try and drive it like that unless I could disengage the power steering somehow.
Posted : 22/11/2011 7:29 pm
 5lab
you probably won't even notice heavy steering above ~ 10mph, above the PAS has much less effect
You can always call someone burly when it comes to parking it. 😛
Posted : 22/11/2011 7:49 pm
Steering lock will only engage with keys taken out if the ignition. If it's hydraulic steering then it'll be very heavy, but no further damage likely to ochre. Electric, **** knows!
Posted : 22/11/2011 9:22 pm
Hang on...it isn't the pink Ferrari is it? 😯
Posted : 22/11/2011 9:24 pm
yeah, can you park it for me in the morning at the Priory clinic? Ta.
Posted : 22/11/2011 9:33 pm
