Boiler Plume Extens...
[Closed] Boiler Plume Extension - easy to do?
[#5801772]
Or, more importantly, does it really have to be fitted by a Gas Safe person? It's a simple plastic pipe, after all...
Posted : 27/12/2013 2:34 pm
Technically it does need to be fitted by a gas safe person. However it's dead easy of you get the right parts, they just push fit together.
Get it done
Posted : 27/12/2013 7:47 pm
The main concern, and possibly the reason to have someone qualified look at it, is why do you need one fitted ?
If it's because the flue termination isn't sited correctly, then a Plume Management Kit won't solve that problem really.
There is still the air intake to consider, and that won't change.
Posted : 27/12/2013 8:12 pm
Best to check the manufacturers instructions to see if your situation complies,then go from there.
Posted : 27/12/2013 8:19 pm
Please consult a Gas Safe registered engineer, as there [u]are[/u] regulations as to where you can terminate a flue. There is also a maximum permitted flue length specified by the manufacturer.
Also the emissions may need adjusting on the boiler due to increased resistance on the flue (due to more bends & increased length) I certainly would.
Ben. Gas engineer.
Posted : 27/12/2013 8:43 pm
Cheers - problem is at the moment it terminates in a narrow dead-end passageway about 3ft wide, facing the neighbours. so probably not brilliant siting to start with, and we've got plans for the passageway.
I was just asking because it seems easy to buy online, and it's hard to get definitive info on what needs to be done by a Gas Safe person and what doesn't.
Posted : 27/12/2013 8:59 pm
It really all needs to be looked at/ discussed/ decided upon with a decent engineer who knows what they're doing.
Have a look on your boiler manufacturers website for approved engineers.
Posted : 28/12/2013 6:26 pm
