blood pressure 144/...
[Closed] blood pressure 144/63 anything to worry about?
 DT78
[#7073155]
Googling seems to suggest might be hypertension?
Posted : 18/05/2015 10:00 am
Well 120/80 is considered "normal"
And systolic over 140 or the diastolic over 100 is considered as hyper-tension
You have a fairly low diastolic.
When, how was it measured?
If it was sat on the couch after chilling out for half an hour then its quite high, if it was in the office after a meeting with HR then its probably okay!
See your GP anyway
Posted : 18/05/2015 10:09 am
 DT78
Wife is being looked at by midwifes so as im bored i thought id use the machine to see mine. Last had it checked a few years back and it was similar. Seems to be a big difference between the 2, google suggests more than 40 is bad...
Posted : 18/05/2015 10:16 am
My laypersons 2 cents.
Your top end number is at the top of normal. Your bottom end number seems quote low though (that's actually harder/impossible to treat). From memory I am 140/90 which is definitely on the high side but not sufficient to need medication, yet.
Posted : 18/05/2015 10:41 am
Always best to rely on Google and STW for medical diagnosis 🙂
Get yourself to your GP. He/she may well get you to do a 24hour BP monitor as a first stop.
Really, this is a no-brainer.
Posted : 18/05/2015 10:45 am
Hmmmm. Have you bummed or shared needles with any cats in the last 24 hours?
Posted : 18/05/2015 10:47 am
 TomB
One off reading- wouldn't worry. Consider lifestyle, age and family history risks, if you're worried, see gp.
Posted : 18/05/2015 10:49 am
Sounds like you should get it checked by a GP. Mine was hovering in the 140-150s for a few years, before I bit the bullet and accepted the situation (essential hypertension) and went on tablets.
That was about 6 years ago now (I'm 38 now). No side effects, just a healthier level of BP, which is nice (I hover around the 120-135 mark now).
Posted : 18/05/2015 10:52 am
Clearly what @grizedale says do go and see your doctor. FYI my blood pressure dropped quite a bit when I was in Singapore, IMHO due to 1) warmer climate 2) yoga 3) being 14,000 miles from now ex-wife - of all of these I think the last one was the most important factor.
Posted : 18/05/2015 11:46 am
This.
Posted : 18/05/2015 11:47 am
thestabiliser - Member
Absolutely this - worst case of Cat Aids I've ever heard of!
Posted : 18/05/2015 11:48 am
Is it bothering you? Do you feel ill? If not dont waste a GP appointment onthe basis of a one off BP reading taken in a place where you're probably not entirely at ease.
You wouldnt call the coastguard if you fell in a puddle now would you? 😀
Posted : 18/05/2015 12:00 pm
You do know you're supposed to wrap it round your arm don't you...? 😳
the number will rise sharply in about 6 months time and drop slowly over the next 2 years 🙂 congratulations and good luck
Posted : 18/05/2015 12:09 pm
 DT78
Will book for a routine check up p, its overdue. As for symptoms generally Im ok but i do get occassional dizzyness when i stand up too fast or get too hot.
Posted : 18/05/2015 12:57 pm
 DT78
Thanks for the congrats...c section on thurs so a little closer!
Posted : 18/05/2015 1:03 pm
 hora
I've just been rectally examined by a young female GP and an older GP. My blood pressure rate was 152/90...
I wonder why?
BTW Caffeine causes a dramatic spike in BP
Posted : 19/05/2015 3:01 pm
If you do book an appointment about this, make it with the practice nurse or even better healthcare assistant not the GP.
Studies have shown BP readings taken by doctors tend to be higher than those taken by nurses.
or buy your own machine and check it at home over a period of a few weeks. If it's consistently raised then see your GP.
If you are over 40 you could qualify for a NHS health check which also measure cholesterol blood sugar and kidney function.
Any lifestyle factors to address?
Cigs
Booze
Weight
Salt
Lack of regular exercise
Address those first.
Posted : 19/05/2015 3:31 pm
so you presented with raised BP and they responded by examining your arse? I'd be looking for a new GP if I were you
Posted : 19/05/2015 3:32 pm
 hora
Perenial abcess..
Posted : 19/05/2015 3:43 pm
AAAAAAAAAAAAAAAARRRRRRRRRRRRRRRRRGGGGGGGGGGGGGGGGGGGGGGGGGHHHHHHHHHHHHHHHHH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Why did I read that?
Posted : 19/05/2015 3:44 pm
 hora
😆 Im currently sat on one cheek. Im certainly not a prude/hold back on detail..
Posted : 19/05/2015 3:46 pm
He went to the local Benny Hill surgery....
Posted : 19/05/2015 3:48 pm
 hora
Last time I had Jocks itch it was a female Locum. Trust my bloody luck. Where are all the crusty old GPs when you need one
Posted : 19/05/2015 3:50 pm
Perenial abcess..
typo of the day! I hope for your sake it only feels like it's perennial (I assume the word you wanted was perianal)
Posted : 19/05/2015 5:49 pm
White coat syndrome?
Get another check.
Posted : 19/05/2015 6:44 pm
Wrong sized cuff being used......gives really erroneous results! 😆
Posted : 19/05/2015 7:37 pm
