Asgard Bike Shed Pa...
[Closed] Asgard Bike Shed Padlocks
[#7861189]
Tried the search and nothing popped up.
We've ordered an Asgard 4 bike shed, are :
http://www.asgardsss.co.uk/bike-locks/disc-padlocks
The Asgard locks the best ones to go for? If not what do people suggest?
Thanks in Advance.
Jon
Posted : 31/05/2016 10:05 pm
I think you can get similar ones cheaper elsewhere, but I ended up buying the Asgard ones as
A) I didn't want to buy some that didn't fit and then pay double postage to get the recommended ones afterwards (I'm tight!)
B) you get 2 locks in a pack that share the same key which makes it a lot easier to lock up when its pissing down and you want to run indoors!
Great sheds, mine look as good as new after about a year of use.
Posted : 31/05/2016 10:17 pm
I decided to get the best padlocks I could find which were the Abus 20/70 70mm Diskus Plus from Big Red Toolbox.
Posted : 01/06/2016 7:34 am
 gray
The Asgard ones are pretty cheap. I didn't order those because I wanted something a bit more secure, so I also got Abus Diskus Plus. They can also be bought in a pair with one key for both.
As it turned out, Asgard accidentally delivered me their locks anyway, and when I called them they told me to just keep them. So they're sitting here in the shed somewhere unused. Probably cost more to post than they're worth though I imagine.
Posted : 01/06/2016 9:48 am
Very simple to pick...
Posted : 01/06/2016 11:31 am
If it helps, the military use Abloy 330/350 locks on most of their gates or things that need securing. They're not cheap but I can imagine they were picked for a reason.
Posted : 01/06/2016 11:36 am
The good thing about the Asgard design though is only the barrel of the lock is visible when the shed is locked so it would be virtually impossible to get the pick in the position required on the video above.
Posted : 01/06/2016 11:47 am
I suspect they just use different shaped picks....
Shame such an expensive tough lock has such weak innerds....
Posted : 01/06/2016 11:52 am
footflaps: that video is for a less secure model of the Diskus lock, not that I'm saying the lock isn't pickable, but as you'll see in the video (did you watch it?) it requires quite a bit of skill to pick, which your average scroat won't have.
As with any bike security, you just have to make your bike harder to nick than your neighbours'
Posted : 01/06/2016 6:41 pm
