I need to know how much an ATM weighs as I need to justify the floor on which it is sitting! It is a boxed out area that is 3.5 x 1.75m, and it is one of the high street bank ones (not one of those ones that charge you and fit into shops)
Any help would be greatly appreciated
Thanks
you'll need a decent truck to get one of those out. Standard pick up probably no good. I'd go for a big van, maybe with an engine hoist? some of those transits are quite quick to aid escape.
How good is a Transit fully loaded? Does it still corner OK as I know that the engine has to be worked pretty hard anyway so I would need to keep the momentum up on roundabouts and the like
if u get a big engined transit with some good tyres on u will be fine? lay it down in the back? how r u gonna get it out of the wall?
[i]Does it still corner OK as I know that the engine has to be worked pretty hard anyway so I would need to keep the momentum up on roundabouts and the like [/i]
Unless you expect to have the rozzers in pursuit I'd just worry about goign slowly enough that the load doesn't slide around when you're cornering and have the whole thing over than the nuances of Transit handling at speed...
Just get a good run up and rip it out.
I'd not thought of these issues. I suppose the best way would be to remove the cash insitu. £50000 in £20 notes is about a meter long, £25 in £10's is about the same. Just a few large sacks and some "jaws of life" should do it?
It is a 330mm thick loadbearing solid masonry wall so will take some pulling.
Guessing no-one can help with the original question though!! Is it finally a question that can't be answered by STW??
The actual ATM itself comes in at about 70kg without cash, but the safe will add a fair bit more than that, depending on what option it has. That's assuming it's the type with 4 cassettes (which it sounds like from your description). I haven't had much to do with the safes, but you should probably figure in 300-400kg for it.
Isn't suggesting there's a question that STW can't answer heresy?
[url= http://www.****/news/article-1118768/Hole-wall-JCB-used-steal-cash-machine-containing-21-000.html ]JCB is what you want[/url]
[url= http://www.tritonatm.com/products/ft5000/index.php ]Don't know if this answers anything[/url]
You need somewhere quite to disable to die packs otherwise you and the floor will end update painted purple.
"You were only supposed to blow the bladdy doowrs off!"
It's a bit like filling a photo coppier
Only the paper's more expensive.
are you going to just rely on the answer from here? 🙂
686kg, anyway.
This is what you want:
[img] http://www.thenorthernecho.co.uk/resources/images/790415/?type=display [/img]
[url= http://www.thenorthernecho.co.uk/news/4071265.Cash_point_ram_raided_with_JCB/ ]Cash-point ram-raided with JCB[/url]
The local scousers tend to use a JCB when they lift one away into the local woods.
