Any ideas for re-en...
[Closed] Any ideas for re-enforcing shed roof ?
[#467726]
After my shed door got smashed in & inbred nicked last month I had a new reinforced door fitted & a bolt bar put on plus alarmed. The ****ers tried to rip the felt roof off yesterday in broad daylight(!), fortunately a neighbour spotted them before they could do any real damage.
Has anybody any ideas how I could strengthen the roof ? It's a small wooden shed so I know my options are limited to deter a pro. Thought about thick chicken wire on the window.
Neighbour said they looked 13/14, no doubt enjoy their holidays to the full.
Happy easter
doglover
Posted : 13/04/2009 9:52 am
Should be reasonable easy to do some reinforcing inside with coach bolts etc? Big wood/metal/etc.
Posted : 13/04/2009 9:55 am
I'd stake out the joint and batter the ****ers senseless, then find out where they live an lay one or ten on their parents.....and kick their cat/dog/fish/rabbit in the bawls.
Ok maybe i'm overacting.....
Posted : 13/04/2009 9:59 am
How about using some big capacitors wired to a grid under the felt, something like a camera flash charging circuit, works a bit like a taser but not as powerful. Can give a nasty belt but not usually dangerous! Should put them off (the roof, that is!) B@stards.
Posted : 13/04/2009 10:01 am
Cheers, good idea, will have a look into that Brant.
Did think of camping out last night(!) Paranoia set in this morning, slept with the window open and woke up 6am in a mild panic.
Can't believe they did it in broad daylight, guess they thought most people were visiting family on easter sunday.
Posted : 13/04/2009 10:05 am
Nice inbred456, was thinking along same lines! not sure how the birds/cats would enjoy it though !!
Posted : 13/04/2009 10:07 am
Chicken-wire over the top of the shed roof?
Posted : 13/04/2009 10:08 am
or they just didnt give a fu@k.
I have an absolute hatred of theiving gypsy pikey scum that break in and nick your gear. i had 2 grands worth of kitesurfing gear nicked last year. Now honestly they couldnt sell it on cos its a very niche market and i know everybody close by, and they defo couldnt use it so im pretty sure it got binned or set on fire.
best to get into the shed and make sure its as secure as poss by trying to break in yourself and see where the weaknesses are. Unfortunatelly mate wooden sheds are pretty easy for pikeys to get into.
Posted : 13/04/2009 10:10 am
 mrmo
razor wire tacked on to the roof?
Posted : 13/04/2009 10:19 am
Yes ilke the idea of very thick chicken wire over the roof, bent over the sides and secured to edges plus reinforcing from inside, razor wire might hurt the ****ers, bless em.
Posted : 13/04/2009 10:24 am
You could also stick some of those carpet nail strips under the eaves, that'd be fun for anyone who tried to lift the roof off 😈
Posted : 13/04/2009 10:41 am
I got fed up of the felt roof leaking every couple of years, so I re-clad the roof in 1.6mm sheet aluminium. 7 years later its still perfect.
TBH its not got my bikes in so security wasn't in my mind but you would have to lever the whole roof off to remove it.
Use [url= http://www.screwfix.com/prods/38619/Building/Builders-Metalwork/Builders-Band-20mm-x-10m ]Builder's Band[/url] to secure the roof to the side panel joists - run it up one side, over the roof and down the other side - either inside or out. It will hold it all together and make it hard to get through or prise the roof off.
Posted : 13/04/2009 11:08 am
Make an internal cage out of [url= http://www.thesitebox.com/Category/4109/unistrut-channel.aspx ]Unistrut Channel[/url], and weld the joints. Then you can coach bolt the roof / sides to this. Should make any wooden shed a fair bit more robust.
Or buy a big hungry dog.
Posted : 13/04/2009 11:13 am
as above builders band, lots of screws, and possibly the use of dome head bolts, bolted through the roof into the joists etc, wrap the band obver the top and down the sides.
Posted : 13/04/2009 11:15 am
I'm insulating my shed between the frame work and then cladding the interior with 10mm ply screwed every 300mm. Whilst this may not stop them completely it will slow them down, it'll also be really noisy to smash through.
Plus it's quite cheap to do and it'll make the winter bike fettling that bit more comfortable.
Posted : 13/04/2009 11:23 am
Thanks for the all ideas guys, great stuff. Enjoy rest of the weekend.
Posted : 13/04/2009 12:08 pm
put a rabid dog in the shed
Posted : 13/04/2009 12:37 pm
 Si
Sniper?
Posted : 13/04/2009 12:52 pm
Screw these to the edges of the roof. They can be cut down into single rows if required or bent round the corners of the roof.
[url] http://www.thesafeandsecurestore.com/shop-by-brand/prikka-strip?gclid=CJvR_5Oc7pkCFQkEZgodd1-4Qw [/url]
I've got them on my fences and gate. They have kept the little ****ers out of my back garden so far. They have kept the window cleaner out too.
Posted : 13/04/2009 4:59 pm
One of the banks that I work with specify a sandwich of ply - mesh - ply to the underside of ceilings to branches where they have flats etc above. Same principal would work well on a shed roof.
Posted : 13/04/2009 10:16 pm
I dismantled a shed in my back garden a few years back. The previous owner had put silicon sealant all round where the roof met the walls. It was an absolute pain to get the roof anf took ages. That would certainly slow them down and would be cheap to do.
Posted : 13/04/2009 11:32 pm
Do the strengthening thing with coachbolts & plates. Maybe line the edges of the roof with silicon & broken glass (Small so no one complains about big lumps of glass but enough to shred someones hands). Maybe one of them cheap movement detectors inside like you get from Aldi etc. An alarm will scare off most.
Posted : 13/04/2009 11:48 pm
Fix three quarter inch shuttering ply over the existing roof nailed down using ring-shank nails into the solid timbers. Re-felt.
They won't lift it off and they won't be able to smash their way through it. Use the ply over the window too.
Posted : 13/04/2009 11:58 pm
If the roof is made more secure they will go through the walls.
Nice bikes live in the house.
Posted : 14/04/2009 12:10 am
TBH if they're really determined they'll take the whole shed & work on it later
Posted : 14/04/2009 12:20 am
yes agree shed aint the best place, with a 1 bedroom flat it's the only option at the moment, apart from giving up riding or shifting the g/f out to the shed.....mmmmm
thanks for the all ideas...will keep you posted.
Posted : 14/04/2009 7:21 pm
on a legal front anti vandal paint might piss them off
maybe that plastic coated 4" wire mesh fencing applied to roof.
can you get a cctv with a view set up...
Posted : 14/04/2009 7:27 pm
yeah anti vandal paint could be do-able.
Don't have leccy down there for CCTV but thinking longer-term this may be a good option to at least give the police something to go on. Cheers.
Posted : 14/04/2009 7:39 pm
