Any experiance in N...
[Closed] Any experiance in Neoair repair.
[#7381834]
After 6 years the inevitable has happened.
Hastily set up sleep site in a bothy and i managed to sleep on a staple embedded in the paint :/ it was obvious in the daylight,
Woke up on a flat neoair after a good nights sleep.
Ive found the hole - its in the bottom - its a pin prick as you would expect.
The base is polyester - so ive been advised not to use a puncture repair kit - vulcanising rubber is not what i need apparently.
I have a stormsure repair kit - looking through that im wondering if i can get away with just using the glue - even if it is on the outside of something under tension - which is similar to a tent where even stormsure suggest not using theri glue.
Ive been reading other pages that say a drop of superglue on the hole should seal it.
The hole is in one of the valleys of the ridges on the bottom so getting a good seal with a patch is going to be hard
Posted : 10/10/2015 12:32 pm
Don't they come with a repair kit? Could've sworn mine did, but I may be misremembering.
If it's a pinhole, you might get away with just smearing glue over it. I did that with a Fat Airic a while back.
Posted : 10/10/2015 1:07 pm
Nah , mine didnt even come with a stuff sack . I bought it back before they had come to te uk - so potentially olde than 6 years even :/
Aye am tempted to try smear of stormsure over it and let it dry. Will "need" to go take it for a test ride after though 😉
Posted : 10/10/2015 2:33 pm
 kcal
I've just got some kind of neo air mat - I'll look and if it comes with a kit I can fire it over Terry...
Posted : 10/10/2015 2:41 pm
I bought mrs t-r a meoair trakker the other week from cotswolds , im pretty sure it didnt come with orne and it certainly doesnt have one now.
Gonna give the storm sure glue alone ago just now .
Posted : 10/10/2015 2:44 pm
 kcal
I dug out some kind of Field Repair kit - alcohol swaps, Tear-Aid Patch Type A and a couple of little stick on (like Park patches) -- happy to send some or all. This was also an NeoAir - all round or trekker or similar.
Posted : 10/10/2015 2:54 pm
Stick some fabric on top of the glue, just a little offcut of tent fabric or something, should make it a bit more robust. That or good old duct tape!
Posted : 10/10/2015 3:00 pm
Get a kit from eBay or Amazon.
Posted : 10/10/2015 4:07 pm
Try this stuff, amazingly flexible / tough after it sets.
[img] /440[/img]
Posted : 10/10/2015 5:30 pm
need to borrow someones bath.
Ive repaired that hole - theres nothing coming out of the repair.
it still leaks.- to a lesser extent , cant find another hole.
Only have a shower - bugger.
Posted : 14/10/2015 4:24 pm
Wipe it over with a cloth/sponge dipped in soapy water, the leak will show.
Posted : 14/10/2015 5:04 pm
 kcal
bound to be an old bath in a field nearby t_r ? 🙂
Posted : 14/10/2015 5:10 pm
