I would be very interested in anyone that has any solar panels or turbines also insulation and other good shit!
Anyone want to discuss the matter I am very interested in saving ££££££ 😀
Insulate. fabric first. You really need to tell us about casa kaesae so we can give you some pointers.
Don't run a computer for teh interwebz and games. That should save a bit.
It's an old council flat, think of a gang hut at the top of a lfight of stairs, chalk walls, paper mache doors, enough of the sharing crap.
What is the most cost effective way of insulating chalk walls, remember they do not belong to me 😀
So is anyone willing to share some of the info they have and teach me about insulation and alternative power sources!
[url= http://action21.co.uk/existing_buildings.html ]http://action21.co.uk/existing_buildings.html[/url]
Yes. Simply cut down on your unnecessary energy expenditure. It's pretty obvious, isn't it? That would reduce your energy use.
Then, as above, insulate, insulate, insulate.
HTH.
I don't really use that much energy unnecesary, what about cavity wall insulation, how do you go about doing that ❓
I find that under certain circumstances that the complete opposite is very effective at keeping me warm.
@kaesae Make sure you have cavities then look through [url= http://www.energysavingtrust.org.uk/In-your-home/Roofs-floors-walls-and-windows/Windows ]here[/url] to see if they can point you in the right direction for grant aid.
I'd also think about your motives as a lot of accepted insulating technique have quite long pay back periods, double glazing for example.
By cavities do you mean hollow walls and floors?
Have a look at [url= http://action21.co.uk/existing_buildings.html#walls ]this.[/url]
Council flat won't be easy to do solar or other microgen. Many council or HAs doing it for an array of properties though . As above most impact will come from optimising your currant usage.
Go to Wilkos, buy a couple of tubes of caulk. Stop all the draughts. Then see which walls and windows are coldest and work on them. Heavy floor to ceiling curtains really work, but a bit crap if you have to waste daylight to stay warm. Floor to ceiling bookcases, filled with books, obviously, are pretty good at warming up a cold wall, better still if they have doors on.
Secondry glazing?
Flick the RCD when you go out and go to bed. Ensures nothing is consuming. Buy AA rated appliances.
That's odd, I've found it now... 😳
Heavy curtains open during the day to let sunlight and heat in, closed at night to stop the heat escaping.
Insulation, insulation, insulation.
and for some fun...
Trombe wall 🙂
an old council flat
So - is it your flat or rented?
Check out what mel did with his place in conspiracy theory............
If you are top floor don't insulate under the floor, let everyone else's heat come up to you. Locally (in ayrshire) I'm offered free energy assessments that look at helping to reduce costs and identify the actions to take whether you own or rent the property. Not sure if that's a local or national initiative though.
If you are already pretty frugal and the property isn't that big then savings will be relatively small and the cost of implementing any improvements might take longer to pay for themselves. If its a rented property might be smarter to just move than spend money on improvents
If the walls are so waffy any chance of a sneaky cable drilled through to next door, nip round for cup of sugar, create diversion, plug on plug in, thanks for sugar, back home, fire up the three bar fire 😉
Really? I thought you were more interested in saving the world. 😕
You need to line your walls with egg boxes tinfoil and old carpet.
Consuming the eggs will create methane... try and bottle it and use it for heating fuel.
The tinfoil will also help to protect you from 'them'.
Great! here come the keyboard badass's, lucky I got some good info before they arrived 💡
TSY you still saving a fortune on hair products and cuts by being bald, now that is genius!
Investing the fabric of a property you don't own does not seem like good economics. I suppose it depends how long you intend to live there.
1. Draughts are the easiest and cheapest to sort.
2. Curtains with insulation really make a difference and they are easy to make - sewing is not a black art when you have a machine to do it. If you want to go to extremes to save heat loss from windows make up some demountable closed cell insulation boards that fit into the reveals of the windows - any phenolic insulation board will do, it doesn't have to be the fancy kingspan.
3. If its a flat and you can't get to the underside of the fllor insulating the floor with something like these would make a difference [url= http://www.wickes.co.uk/fibreboard-underlay/invt/215589/ ]wickes[/url] - unless the person the lives below you 'heats your flat!
4. Lagging you hot water pipes and tank.
5. Dry line external walls with insulated plasterboard [url= http://buildingmaterials.co.uk/BG-Thermaline-Basic-Insulated-Plasterboard/p~684~026_155_001-Gyproc-Thermaline-Basic-Insulated-Plasterboard-2400-x-1200-x-22mm.html?utm_source=GoogleBase&utm_medium=Product+Search ]gyproc plasterboard[/url]
6. Insulate ceiling
Have a look here [url= http://www.greenspec.co.uk/ ]greenspec[/url]
eh?by being bald
I could start shaving and sending you the clippings to pack the egg boxes with?
Thanks tomaso I have that green stuff down already, I will look into the other stuff later!
The Southern Yeti - Memberby being bald
eh?I could start shaving and sending you the clippings to pack the egg boxes with?
Wouldn't want to leave you without a hairy back in the winter, so I'll pass 8)
I could be wrong, but isn't the 'green stuff' carpet underlay?
