A new take on the w...
[Closed] A new take on the wood burner threds - What bricks for a chimney?
[#3618661]
I am in the process of opening up my fire place to eventually install a wood burner. I have so far removed one and a half harths, one had been built on top of the other. While clearing out the chimney i have descovered that when the back boiler was installed in the chimney they have smashed out some of the bricks at the back of the chimney.
What should i use for replacing the bricks? is there any type in particular that are suited to being used in a chimney?
Posted : 28/01/2012 10:53 pm
Mine was built with the same bricks as the rest of the house.
Unfortunately they were textured bricks, one side and end, but laid any ways, looked a mess and had to be covered up.
Posted : 29/01/2012 12:15 am
Reclaimed red brick here that matches the house brick, old Pegswood brick you could smash diamonds with them.
Posted : 29/01/2012 12:17 am
These bricks will not be seen when I am Finnished I just need to know they will be fit for purpose - strong enough to support the chimney and also be able to cope with the heat generated eventually. My plan is to plaster into the chimney so I can have the wood burner part in part out of the chimney brest to give me a little extra space in the living room.
Posted : 29/01/2012 11:01 am
