I've been using about 40 of these for the last 6 months and I'm really impressed. Colour and brightness matches our existing 50w halogens but the LEDs have a better/wider beam pattern.
Although ledhut have regular offers they never seem to exceed 25% discount but the base price of these bulbs has now been dropped from about £14 to £8.99 which I reckon is a bargain.
[url= http://www.ledhut.co.uk/new-5-watt-gu10-led-bulb-wide-beam-angle.html ]ledhut.co.uk/new-5-watt-gu10-led-bulb-wide-beam-angle[/url]
So if anyone is after some new bulbs then now would be a good time to buy (even though the nights are getting lighter). Having seen the amount of burnt wiring that's been sitting above our halogen downlights I personally see changing to LEDs to be a safety exercise.... the money saving is a bonus.
don't recommend LEDHUT
I bought some led bulbs of them and one flickered like made and the other one burn't out within the first day, so sent them back 2 month ago, no reply, no money back and no replacement!
40? Holy shit, are you a hospital with an operating theatre?
We went for the 4 watt ones. Even cheaper at £6.99 (plus 10% discount with "10today" code).
Seem brighter than the 50w halogen they replaced and definite wider (120 degree)
Quite cold colour temp but fine for the kitchen.
ledhut service was good for me
Hora;
Kitchen/breakfast = 18
Hall = 4
Dining = 6
Landing = 8
Bathrooms = 11
So 47 to be exact.... madness! When they were put in (12 years ago) 'leccy wasn't so bad but now it is. To be honest the house is quite big with lowish ceilings.
Just buying 25 for another house 🙁
Why do they have a random picture of Sarah Benny on the home page?
I believe she is a "Brand Ambassador" - see http://www.ledhut.co.uk/savvy-switch
At 25W a go for halogens that's over a kW of power just on lights! I bet your house is a bit colder now 😉
I got the 7dayshop mailshot yesterday
Has anyone got those bulbs, they look very cheap so I'm wary
Screwfix do a box of 10 LAP ones for £49.99...
Nope but thinking about getting some, I've used 7dayshop for loads of stuff over the years and not had any issues with anything.
Drac - same here, so very tempted by the box of 10 deal
Only loosely related but I put dimmable normal style LED lightbulbs from B&Q in our living room, but also changed the dimmers for a third time. Finally got it sorted, and 10W LEDs seem far brigher than their claimed 60W equivalent. Very happy.
Most of them were 50w! Obviously most of the heat generated from the upstairs lights simply went into heating the loft 🙁
Yup a proper bargain of less than £3 a bulb.
Fitted 8 of these in my kitchen, much better than the 50w ones they replaced.
Gf has stopped moaning about them looking like yogurt pots once I explained that they used 90% less energy.
All still working well after 3 months.
http://www.screwfix.com/p/lap-gu10-led-reflector-lamp-with-reflector-330lm-5w/91534#
Shite.. 2kw then.. that'd like having a kettle on all the time!
I paid £20 each for 11W CFL GU10s a few years ago 😳
molgrips, when I moved in last year our house was wall to wall (37 of them) with 50W GU10s. The kitchen alone had 12, so 600W of lighting. Utter madness.
Oh, and the lounge had 6 fittings with 2x 25W golf balls in. Another 300W. Nearly 1kw to keep the lights on!
Sharkbait, have you got any of the dimmable ones?
Partially sighted previous owner?
After switching that many lights on, I'd have thought so
Another recommendation for the OP's bulbs and Ledhut here, just replaced all our kitchen with them, and bathroom with the equivalent fitting ones
Bought some transformers in case the bathroom transformers weren't LED compatable but ended up not using them, LEDhut refunded no problem
Now can anyone recommend a decent multidirectional G4 LED bulb around 100-120lumens?
I need 22 of them for the living and dining rooms
Right, so I currently have mr16 halogens, with individual transformers for each. Am I right in saying that I can remove each transformer, wire in a gu10 130mm tail and use those LED bulbs in existing mr16 lamp holders?.
Still think Kosnic 6W's are best, can be got for £6.75'ish trade. They also list the correct colour temp i.e 2700/4000/6500 so when a few go and the ones you bought on the net don't exist anymore you have a temp to match.
Nobeerinthefridge
Assuming your transformers are compatible just get the mr16 equivalent
You may need new transformers
http://www.ledhut.co.uk/led-driver-transformers/6-watt-led-transformer-driver.html
Monky: yes 9 dimmable ones with a trailing edge dimmer from ledhut. They're very good, can't tell the difference between them and the non-dimmables and they're right next to the them in the same room.
When dimmed they don't go warmer, unlike halogen, they just get dimmer.
The cool bit is that when you switch them on the electronics in the switch start them low and then build to full brightness over about a second.... still neat!
Nobeer: Yes, that's exactly what I did. No more transformers to blow 🙂
Don't get new transformers or go MR16 - what's the point? Plus you can sell the old transformers on ebay for a few quid each.
He already has MR16 and transformers so isn't 'going' MR16, assuming his transformers are compatible he doesn't need to mess around with tails, just replace bulbs with MR16 LED's
