+/- 4mm on a custom...
[Closed] +/- 4mm on a custom kitchen worktop...
Both ends were already sealed by the manufaturer however I had to cut two small notches at the front which I sealed with silcone. I'm going to get my mate to silicone around the sides and back of sink as he's a LOT better than me..
That Stanley tape with the typo in.. Wonder how many of those made it out of the factory?! Reckon a fair few people would have been scratching their heads over that!
Posted : 19/01/2015 5:53 pm
Siliconing is easy. But ONLY if you use green Frog tape along both sides of the line and you have plenty of white spirit to wet your finger and masses of paper towel to wipe the excess off.
I've tried dozens of time without the tape. And made a horrid mess. With the tape, great results.
Posted : 19/01/2015 6:18 pm
[url= http://www.amazon.co.uk/Cramer-FUGI5-5-Fugi-Kit/dp/B003BNLQQ0 ]Fugi[/url] for me.
Posted : 19/01/2015 7:04 pm
Have you gotten to the point where you realised Ikea kitchens are shit yet?
Stupid crappy fittings on the sink waste, crap non standard plugs that don't seal the plughole, lack of services/uneven wall gap at the back of the units?
I'd happily walk round Ikea with a gallon of petrol and a match Falling down style.
and breathe again......
Posted : 19/01/2015 7:34 pm
Fitted two IKEA kitchens. Yeah the lack of service gap is a bit odd. However once you've figured it out I've never found it a problem. Also means you can access stuff from behind the kickboard. Can't comment on sinks as I've always used other brand sinks, same for worktops.
Posted : 19/01/2015 8:04 pm
I would say that if you've got this far(looks good btw) and own a jigsaw, drill etc, Then the cut out is straightforward:
-Ghost fit w/top to fixed/level base units.
-Check hob placement isn't directly under any electrical points or too close to wall units(There is a recommended distance somewhere on t'internet)
-Hobs will usually come with template. Measure, dbl check, mark out perimeter with dbl thickness masking tape. Set masking tape to the inside of your marked perimeter. Mark internal lip on tape(allowing a couple mm tolerance).
-Four 9mm holes drilled on the inside corners of marked cutout guide.
-Carefully join the dots with your jigsaw. Use a lam. specific blade or a medium toothed metal work blade(cheaper, just as effective) most jigsaws have an oscillating function to help push through cuts. turn this off and use a med-high speed setting and guide rather than push jig. through.(If you felt you needed to, could clamp a level to outside edge of jig. foot plate to aid straight cuts)
-Support cut out with timber or human. Any high spots can be sanded etc.
-Seal cut edge
-Be mindful that w/top(esp. composite) will be very weak at cut portion
Hope this helps
Re. 4mm tolerance. Can you live with it? Or will it bug you. Did cut sides come laminated? If not would bring either side out a mm or so?
Posted : 20/01/2015 12:57 am
Mekke's method is how id did ours. The ikea hob just came with dimensions to measure out yourself so double tripple and made offerings to the saw dust gobblins before cutting.
The end result
[url= https://farm3.staticflickr.com/2945/15363172306_3e8ee736e9_c.jp g" target="_blank">https://farm3.staticflickr.com/2945/15363172306_3e8ee736e9_c.jp g"/> [/img][/url]
[url= https://www.flickr.com/photos/parkesiemtb/15363172306/ ]House renovations[/url] by [url= https://www.flickr.com/people/parkesiemtb/ ]Parkesiemtb[/url], on Flickr
Cutting the joins for the tops was the most nerve racking bit the sink was marked and cut in situ as moving a 3.5m worktop with a hole in would have ended in tears.
Posted : 20/01/2015 5:57 am
I just cut the sink hole in situ with a jigsaw, was pretty easy as it came with a template, so just traced that out and cut round it.
Posted : 20/01/2015 10:19 am
What's the verdict on IKEA kitchens then? Looking at getting a new one and the pricing seems very good - I'll be honest I can't tell the difference between any I've looked at but the price varies massively- wouldn't be fitting it myself
Posted : 20/01/2015 12:18 pm
[i]wouldn't be fitting it myself [/i]
find a fitter and see what they recommend would be my advice.
I went down the DIY route but with kitchen supplied by a local company that manufactures on site so that when/if there were issues I could get bits quickly.
Posted : 20/01/2015 12:20 pm
The new ones are very easy to fit with their rail system. Makes it pretty idiot proof for lining everything up. I'd be tempted to have a go then just get someone in for the worktops.
Quality is pretty good. I took out a 10 year old(ish) Ikea kitchen. Re used a load of the bits, some in the new kitchen, some in the utility. Quality of the new stuff is on a par if not better than most other places. I much prefer their pricing and order system too. You can do it all yourself, work out all the options, tweak it, etc then just present them with a list. No need to deal with idiot salesmen and negotiate fake discounts. They are good for spares and returns if you do have any issues (even those of your own making)
Posted : 20/01/2015 12:27 pm
 IA
Just fitted one, came out really good. A few comments:
Ignore or treat with a big pinch of advice anyone advising based on experience over 1yr old - they changed the kitchen system for the first time in 12 years last year. The new stuff is quite different in some respects, a mate did the old style last year so I'm fairly aware of the differences.
As above, if you're getting a fitter, get their advice, but some points to consider in no particular order:
o Ikea cabinets go all the way to the wall basically, you need to run services under them, or very tight to the wall. In my case, all the services were "within" one cabinet so it worked well, and I have a freestanding cooker so no issues there.
o The newer METOD base cabs go very low to the floor - there's not much gap underneath.
o Ikea cabs are deep. A standard 60cm worktop won't cover them properly, ikea tops are 63.5cm.
o They come in 20cm size intervals, up to 80cm wide, wall cabs up to 100cm tall.
o The above points (low, deep, tall) mean they're far larger inside than pretty much anything else, you get a lot of space.
o they have a lot of cunning/useful drawer options.
o the "maximera" drawers (soft close) have MUCH nicer runners (not made by ikea) and let you get them all the way out.
o Plan, plan, plan. Think mostly about gaps to allow adjustment when fitting, how you're going to do ends, gaps and angles (which are likely not perfect 90s)
o If you have awkward services, or gaps, consider other makes (howdens, wickes etc) which do e.g. 50 and 100 wide cabs.
o I find the sinks ok, and the trap/waste design very good for my purposes, maybe it's new too compared to the complaints above. My mate with the old style told me he had issues with the funny connections, but mine went straight onto my waste with a compression fitting.
To the OP thinking about hiring a router for the hob cut out. Don't bother. I needed to mitre a join, which is way more of a job. I found a local joiner who came and did the join for me and the sink cut out whilst he was at it for less than I could hire the tools for. Not worth my time and he did a better job than I could. It did take a while to find someone though, as it's a small job (they just need to turn up with tools) so you need someone local/working near by who wants a bit of spending cash for a bit of extra evening/weekend work.
Posted : 20/01/2015 12:37 pm
 IA
The rails are a bit of a faff if you have uneven walls, and for my layout at least involved a lot of holes, some at 240cm height, in very hard bricks. Ladder platform, laser level and SDS drill are your friends.
I took a week off work and did our kitchen. Just fitting the units probably could've been quicker but there were other things to faff about with.
Posted : 20/01/2015 12:39 pm
My brother fitted one and it's looking pretty shabby after only 18months. The drawer fronts are plastic covered fibre board and water seems to leak into the fibre board where the handles screw in. Any drips sit on the handle and are held in place with plenty of time to soak in. The fibre board swells up and splits the plastic cover. Rubbish design.
Posted : 20/01/2015 12:52 pm
IA has pretty much described my experience fitting our ikea kitchen. Id never even thought of doing 1 before but it was a rewarding process the end result looks great works well and the extra space is worth the head scratching fitting the utilities.
Before
[url= https://farm4.staticflickr.com/3859/15363192746_e54dba6c21_c.jp g" target="_blank">https://farm4.staticflickr.com/3859/15363192746_e54dba6c21_c.jp g"/> [/img][/url]
[url= https://www.flickr.com/photos/parkesiemtb/15363192746/ ]House renovations[/url] by [url= https://www.flickr.com/people/parkesiemtb/ ]Parkesiemtb[/url], on Flickr
During you can see the rail system on the wall.
[url= https://farm4.staticflickr.com/3900/15385835752_c58893cb26_c.jp g" target="_blank">https://farm4.staticflickr.com/3900/15385835752_c58893cb26_c.jp g"/> [/img][/url]
[url= https://www.flickr.com/photos/parkesiemtb/15385835752/ ]House renovations[/url] by [url= https://www.flickr.com/people/parkesiemtb/ ]Parkesiemtb[/url], on Flickr
After
[url= https://farm3.staticflickr.com/2945/15386143095_a187e28a9a_c.jp g" target="_blank">https://farm3.staticflickr.com/2945/15386143095_a187e28a9a_c.jp g"/> [/img][/url]
[url= https://www.flickr.com/photos/parkesiemtb/15386143095/ ]House renovations[/url] by [url= https://www.flickr.com/people/parkesiemtb/ ]Parkesiemtb[/url], on Flickr
Posted : 20/01/2015 12:58 pm
We really struggled to find a fitter who would touch them. Then they screwed us around for about 3 months in the design, finally paid for it, noticed a mistake went back to alter the design only to find the units were now EoL.
Cancelled, started again with new units. Their fitter came out for a comparative quote (astronomical btw, but I had the luxury of a Dad who is a sparky and good handyman, so we did a lot) and he pointed out the design wouldn't fit.
Sacked them off after that, bought a Cooke & Lewis (B&Q) which has been very good quality, not much more expensive (worktops from worktop-express.co.uk, as B&Q are standard sizes unlike IKEA), sink & taps off EBay .. did it all including limestone floor and Stoves range for less than the IKEA fitting quote.
So in short, I wouldn't 🙂
Posted : 20/01/2015 1:06 pm
Its a custom size, for which you pay a premium so I'd expect that size.
Unless it states at point of sale about the tolerance I'd be asking for a replacement.
Posted : 20/01/2015 1:08 pm
Thanks for that folks - it's a odd shaped room that's going to need some customization of the cabinets - think I'll find a local fitter and take it from there - the quote from Wickes was insane in comparison to Ikea. Never done it before and much more of a headache than I imagined!
Posted : 20/01/2015 1:38 pm
 IA
Was it comparable work/units though? As in just units, or including fitting?
I found wickes and ikea very similar in cost, but the ikea units were better for us.
The comments about water ingress and splitting etc. seems to be a risk with any cheaper kitchen, as they're all made a similar way. Important to take some care with assembly and sealing where required I think.
Asking people (in general) how much a kitchen costs gets you very varying estimates (about 2k-10k seems a reasonable range). A lot depends on how much you need done to plumbing and electrics, how much you do yourself (it's quite labour intensive), decoration (tiles alone could be a fortune) etc. I would expect with Ikea, as a rough guide, you'd spend about as much on fitting as the cabinets, then add on the extras (lighting, accessories etc)
Posted : 20/01/2015 2:11 pm
That's part what I'm trying to get my head around thanks - trying to make sure I'm comparing apples with apples!
Posted : 20/01/2015 5:16 pm
Our IKEA bill came to about £2900. £400 of that was the custom worktops and the rest was units, sink and tap. Obviously we need to buy oven, hob, etc. on top of that lot but compared to prices we were getting from Wren, Wickes etc. we were looking at 2-3k cheaper from IKEA. You have to build all the units up yourself but that's the easiest bit by far and once you've done 1 they're a doddle.
The new "METOD" rail system is actually very good, however (and as noted above) if you don't have straight walls it is a little more time consuming to get them nice and straight. Not a massive job though, just playing around with packing pieces.
The lack of utility space at the back of the units is a bit of a pain but not a dealbreaker for me given the massive cost difference. I had to do quite a lot of bodging around leccy meter, mains water, waste pipe, etc. etc. but it was still only 4 cabinets in total. It wasn't too bad and who doesn't like a bit of jigsaw action?! Only downside is apparently any cabinet that you cut loses its warranty but I'd imagine this is the case for all manaufactuers.
I'm fitting myself so don't have much of an idea on cost but my very rough estimate is that I'd be looking at 1500-2000 to fit mine (Newcastle prices..)
Posted : 20/01/2015 5:42 pm
Also - getting the design right was critical. We spent about a total of 5 hours with the designers in IKEA (Gateshead Metro Centre) and each of the 3 different people we spoke to were excellent. I've popped down a couple of times since I started fitting where I've unsure on something and they've been more than happy to advise and help.
Posted : 20/01/2015 5:49 pm
 IA
The above sounds similar to me except:
I spent less, for probably a similar kitchen but I have fewer, larger units, and standard worktop lengths that I fitted (or as above paid for the join). My total worktop cost was £200 (inc the join) for a bit over 4.5m of length total. I do have £300 odd of lighting bits though.
I think design is important, but I DIY'd it all - only spoke to staff to order the bits (which I then picked up myself).
When I was unsure I went in and took apart their units 🙂
Posted : 20/01/2015 6:23 pm
Page 2 / 2
