12v Kettles - much ...
12v Kettles - much the same?
[#13535705]
I'm looking to replace my aging flask with a 12v kettle to make a cup of tea in my van after a ride.  Just big enough to make 2 cups (relatively) quickly should be fine.  Is there a market leader?  Or are they all much of a muchness?
Posted : 27/05/2026 10:21 am
Topic Tags
 poly
The power required to make 2 cups of boiling water is quite significant.
If you actually mean “cups” that is 0.5L (if you mean mugs could be more like 1L).
 If you are doing this with a cigarette lighter socket they are often limited to 7 Amps (at 12V) and would take over 30 minutes to boil 0.5L.   Even with a better socket and kettle it will be slow.
if I was doing it I’d take a flask of boiling water and if I really wanted it boiling hear that from 80-100 which will be much quicker.
Posted : 27/05/2026 11:09 am
Gribs and ready reacted
id buy a jet boil if i was dead against a flask.
Posted : 27/05/2026 11:21 am
ready reacted
1kwh power bank and a 600w 1ltr electric pot 🤔.
The power bank will probably have other uses and the £15 electric pot should be able to heat up soup.
£500 well spent 😉
Posted : 27/05/2026 11:27 am
ready reacted
Gas stove and a kettle/pan.  We can do a kettle or coffee maker off our power station but we have that for other 'stuff'.
Posted : 27/05/2026 1:27 pm
ready reacted
 kilo
Kelly kettle, boils a decent amount of water quickly and will add a soupçon of danger to your van life.
Posted : 27/05/2026 1:50 pm
ready and retrorick reacted
+1 on a Kelly/Ghillie/Storm/MK kettle or a wee jetboil knock off...
Posted : 27/05/2026 3:26 pm
ready reacted
I use a jet boil knock-off on my boat when I need a coffee or similar - it's very quick and can also be used with a small frying pan for bacon.
Posted : 27/05/2026 6:02 pm
ready reacted
EV and V2L plug 👍
Posted : 28/05/2026 7:16 am
Posted by: DrJ
EV and V2L plug 👍
A jetboil is slightly cheaper...
Posted : 28/05/2026 2:01 pm
ready reacted
Get a small generator and a normal kettle.
Posted : 29/05/2026 11:05 pm
tomg17 reacted
+1 for a camping stove, with the caveat that you really don't want to be using it in an unventilated space.  If you're going to be coming to a boil whilst hanging out of her back doors then it'll probably be fine.
Also, you've got a fire extinguisher in the van, right?
Posted : 30/05/2026 1:35 pm
