[Closed] ¬
[#7845315]
What is this thing?
Posted : 23/05/2016 1:13 pm
It's a dead one of these
L
Posted : 23/05/2016 1:14 pm
Google search for it is inconclusive, but the image results are quite strange.
Posted : 23/05/2016 1:15 pm
Where did you find it?
Posted : 23/05/2016 1:16 pm
It's called the "not sign" in the ascii table, if that helps.
[url= https://en.wikipedia.org/wiki/Negation ]Logical negation[/url], apparently.
We used it at uni when writing* logical expressions out as the "not" operator.
* as in old skool with a pen/pencil.
Posted : 23/05/2016 1:17 pm
It's not a knot sign.
Posted : 23/05/2016 1:18 pm
Moly
Have you been pulling bits of insects again?
Posted : 23/05/2016 1:19 pm
It's Fred's new login, "the forum member formerly known as PaddedBra".
Posted : 23/05/2016 1:21 pm
I like it as part of a process to strip out multiple spaces in strings -
SELECT Replace(Replace(Replace((@stringexpression),' ',' ¬'),'¬ ',''),'¬','')
(other odd Unicode characters are available)
Posted : 23/05/2016 1:22 pm
Logical negation, apparently.
Yeah, that's it.
The reason it's there is because PC keyboards were based on IBM mainframe terminal keyboards, and the negation symbol was used in some ancient mainframe programming language or other. PL/1? Maybe.
Posted : 23/05/2016 1:28 pm
Oooh, hacky-yet-elegant, I like it...
Posted : 23/05/2016 1:38 pm
I know it as the 'pipe' key. Very useful when used with Ctrl in excel for showing formulas that get hidden...
Posted : 23/05/2016 1:44 pm
 TimP
Is it the emoticon of Alex's finger?
http://singletrackworld.com/forum/topic/i-need-some-happy-broken-fingers-dont-take-long-to-heal-stories
Posted : 23/05/2016 1:47 pm
Hmmm, in IT land, the pipe symbol is a vertical bar ¦
^ that's a broken pipe. The pipe is |
Posted : 23/05/2016 1:53 pm
Confusing, as allthepies says "|" is pipe too, comes from *nix/bash I think. I use Excel all the time and I've never called "¬" 'pipe'.
Also, surrealist coder joke: "|" ceci n'est pas un pipe.
Posted : 23/05/2016 1:58 pm
1964 is the origin of the SW Pipe, although long before Steven Bourne picked "|" as the command....
http://doc.cat-v.org/unix/pipes/
Posted : 23/05/2016 1:59 pm
!in any of the languages I use.
Posted : 23/05/2016 2:12 pm
Apparently no languages use it, but it's still on everyone's keyboard....
I also have both ¦ and |, the latter is the pipe command.
Posted : 23/05/2016 2:19 pm
Except maths...
https://en.wikipedia.org/wiki/First-order_logic#Logical_symbols
Posted : 23/05/2016 2:20 pm
As above, a maths/logic thing. But I've not used it since doing that course at uni, quite some time ago.
That symbol is not on all keyboards. Pretty sure it is on my home PCs (maybe not chromebook or mac... would need to check), but it certainly is not on this work keyboard. A least it is not labelled on a key but might be available via some weird windoze key combo somewhere.
I've always called | a pipe. Have seen the broken vertical also, but again, that one is not on this keyboard.
On this PC, the key that usually has the not symbol, only has the ~ and the backwards ' that stuffs up all the formatting on this forum.
Posted : 23/05/2016 2:31 pm
Posted : 23/05/2016 2:36 pm
The backward apostrophe thing doesn't stuff up the formatting really, it's just a useful way of formatting inline code or other pre-formatted text.
Incidentally Windows Character Map says that ¬ is called the "Not Sign"
If your keyboard doesn't have it you can get it by holding Alt and typing 0172 on your numeric keypad.
(On this Logitech keyboard it is on the top row to the left of the numbers. The broken vertical pipe ¦ is there too)
Posted : 23/05/2016 2:40 pm
Not symbol is very important in mathematics - my memory is a bit hazy (getting old) but I recall back in the day ('late 70's and early '80's) we used to write it as -! on the computer keyboard so my guess is they created a single character to match
Posted : 23/05/2016 2:44 pm
Surely it's there for putting bigger, roman style, noses on simple text emoticons?
No?
Posted : 23/05/2016 2:45 pm
It's on the Dell, HP & Microsoft keyboards I have in front of me currently.
Posted : 23/05/2016 2:47 pm
Interesting - I wonder if that's related to the use of ! to represent NOT in most programming languages. (e.g. true == !false)
Posted : 23/05/2016 2:49 pm
could it be text speak for erectile function disorder?
Posted : 23/05/2016 2:50 pm
Think this is some kind of odd "English International" keyboard? Certainly not UK, and not sure it's US either (might be). Not sure it's a brand thing, but more of a layout thing? (edit: this is an HP keyboard, and just checked the HP laptop, and it's the same)
Odd key combos vary. I'd probably hit AltGr and something to see those on my home PC, but not here. And there's no way I'd remember any of those ALT+xxx code numbers.
Posted : 23/05/2016 2:54 pm
Perchy - thats a drunk one of these L
This is a dead one ?
Posted : 23/05/2016 2:58 pm
ah... bit of goggling... it's a one of them:
so ¬ = altgr+\ and ¦ = altgr+shift+\
but ¦¬«» etc are not labelled on the keys (€ is the only AltGr+ thing labelled)
Posted : 23/05/2016 3:02 pm
 nach
I definitely don't know.
¬_¬
?_?
¬_¬
Posted : 23/05/2016 3:25 pm
(?_?)
Ah unicode. I guess you could say it is..
•_•)
( •_•)>??-?
(??_?)
..symbolic!
Posted : 23/05/2016 3:29 pm
