I'm stuck between deciding on Factory Arch Ex or Crest on Hope Pro 2s. I'm 6"1 and 90kg which is about 10 pounds over the Crest's limit. I ride a Carbon Giant XTC advanced and want to keep it as light as possible. I ride mainly xc in the Peaks and from home. I rarely get off the ground but don't mind hammering single track. Does anyone have experience of 650b Crests and do they flex much? I've read reviews where people have said they have crumpled under very little stress. Any views greatly appreciated.
For your use I'd say you'd be Ok with a Crest rim.
I used have a 26 wheelset with Crests and was impressed by them. I also weigh around 90kg and at the time used to ride a long travel hardtail and liked to get the wheels of ground. Usual riding is in soft loamy woods but did many trips to wales, peaks and lake district and they coped fine with the rockier terrain.
I have a set of 29er Crests built on Superstar hubs. They're definitely flexy (or flex[i]ier[/i] than similar 26 wheels I've had, this being my first 29er, but 29er wheels are on average flexier than comparable 26 counterparts as I understand) but seem tough for their weight class. In corners the tyres rub the Mucky Nutz fender I have on the fork, but it's a big tyre and very little clearance between the tyre and fender.
At your weight I wouldn't go near crests, partly for flex, but also because the rims ding easily for anyone that rides hard ime. I was 20kgs lighter than you and still managed to destroy mine (albeit on a hard tail). Someone will no doubt be along shortly to tell me that it's because I'm a shit rider again. My arches have held up better to abuse.
I'm 6'2" 90kg with trail kit, and found crests didn't stay true for long, wheels were a decent build by Merlin too. Now run Hope Pro II evo's on Arch's and stiff as you like, bike still under 29lbs and running a bontrager 2.4" upfront tubeless. Whole heartedly recommend Archs. (although I am talking 26" here)
With 650b your comparing 355g vs 420g so 130gram extra on the bike, 0.28lbs, worth it for the extra stength IMHO especially for some of the Peak descents.
Are those who are saying the Crest will not be strong enough taking into account bluebouye's bike and riding style?
Maybe I got lucky with my wheelset? But mine stayed nice and true, I regularly ride small to mid sized drops and like to pop off any trail features. I also was lacking skill at that point so probably not the smoothest landings either.
Bluebouye, you are border line between the two, depends on how much you value the small weight saving of the Crest. If you really want to keep the weight down go for Crests.
Whichever you choose it'll be a right bastard to get a tyre on the rim!
I found UST tyres where almost impossible to get on.
Specialized tubeless ready tyres went on without a problem and standard Maxis tyres with EXO side walls went on no problem and inflated and sealed with no problems.
I've got 29er ZTR rapides (which are just OEM crests with eyelets).
I'm 100kg and not afraid of some airtime, and they're on a rigid bike, so take some stick too. No issues with them, but then I won't complain if/when they fold either, I'm well over the weight limit and try not to hang about.
I've also go Arch-EX rims, likewise they're good. Probably quite a bit stiffer, but it's oddly not been that noticeable, I notice flex in changing forks more than I do the wheels. they are noticeably heavier to accelerate though, but they're still light enough not to care.
My Crests have never been trued or touched, they are straight and take all that my poor technique can throw at them (admittedly I'm far from weighty)
Re did them tubeless with Chunky Monkey and Smorgs the other day, they went straight on with no trouble and inflated with a shit £5 pump from Aldi.
Currently deciding on whether to go Crest again soon on my 27.5 full susser (that I don't actually have yet)
Oh yea, for the full house of anti STW opinion, they were built by Superstar and were superb from the off.
Boom!
Or - if you're not set on Stans - consider Ryde rims. The Trace XC is lighter and wider than the Crest EX; the Trace Trail is wider and the same weight as the Arch EX. Both have a weight limit of 100kg.
Thanks for all your opinions. Oooooooh what to do!!!!!!!!!...... I cycle for fitness more than the thrills so I'd like to keep the weight down as I'm riding a carbon hard tail with a XTR/XT mix. I suppose I want my cake and eat it as I want a set of wheels that would compensate for my average biking skills and the odd mad descent but a nice set of light, quick accelerating wheels. I suppose the weight penalty isn't that great if I go for the Arches but so tempted to go with Crests and see what happens...........Cheers for your thoughts, I knew you lot would come good
Just what I'm trying to avoid!!!!............what rim was it?
a 26 inch crest!
Crest on the front, arch on the back? Ran that nae bother for 3 yrs and heavier than you - good build from Moonglu. Wheels on the ground, though.
A few kg lighter than you and ran crests for a few months, but they were very flexible and not very resistant to dings. I'd definitely go for something stronger anyway, sounds like you should have the strength to cope with a few extra grams.
I've got 29" Crest & Arch's,I'm a similar weight too. What I've found, the crest are a bit lighter, (ok so that's a given), but overall I'm generally quicker on the Arch's, they flex less & seem "snappier" than the crests.
EDIT- & the Arch's need truing less often as well
Cheers guys. I'm more and more swayed towards the Arch's the more I hear your thoughts. The weight penalty is minimal at about 140g per pair (I think my legs can cope with this weight increase!) and I'd swap that for a stiffer wheel any day than find myself and my front wheel mangled at the bottom of a descent.
Arch Ex are great but I find Crests are tougher than people give them credit for if you're not a hucker or big powerful rider.
Crest F Arch Ex R is a good combo.
(& my experience is on 29, presumably the 650b are stronger).
I've got 650b Crests on ZTR 3.30 hubs on my carbon XTC, but I only with 70kg. They are quite a bit stiffer than my 26" Crests, but those only have 24 spokes.
I also ran Crests on my 29er SS but managed to ding the rear to the point that I couldn't run it tubeless. Changed to Arch for the rear and has been trouble free since.
Bluebouye, are you going tubeless?
Sorry if missed it in one of the posts. But if you were planning on crests with tubes, get Arches and go tubeless, weight increase negated. I know crests can go tubeless but i've found my Archs always held the air better and never burped.
Also 65gram a wheel, go and weigh out 65 gram of rice and hold it in hand, from a rotational weight point of view its absolutely minimal, I really don't think you'll be able to see even a millisecond of 0-20mph lag 😆
I've 2 pairs of 26" Crests (on Hope SP's) and bought them when living down south, light and stiff.
But, since moving to the Borders I've managed to split 3 of the rims and been through loads of spokes/re-tensions. They just can't take the beating that heavier/stiffer rims can and the rocks/roots around here.
I've since got a pair of Flow EX's, and while only an extra 100 or so grams per wheel - different league in terms of stiffness.
Only 80kg and all run tubeless.
Yes cruzcampo I was intending to go tubeless and your point is well made. You're right on the weight difference too. I put a water bottle on me kitchen scales, filled it with two swigs of water......hey presto the difference in weight. I think i was getting hung up on the weight thing.
