Zee Rear mech with ...
[Closed] Zee Rear mech with Shimano 105 STI shifters - WILL I DIE?
[#6596680]
Hi,
Wanting to make my CX a 1 x 10 setup. I want to use a clutch rear mech however. So, Can I use a zee rear mech (shortcage) with Shimano STI shifters (105, if it matters).
Thanks.
Karl
Posted : 30/10/2014 2:37 pm
Different cable pull innit?
You won't be able to go fast enough to die, your gears will be chattering all over the shop...
Posted : 30/10/2014 2:40 pm
nope, no current option to run a shimano clutch mech with road sti. 10s mtb stuff runs a different pull ratio to the road stuff.
EDIT: beaten to it
Gah. Thanks for the swift responses.
Posted : 30/10/2014 2:43 pm
Although....
[url= http://kayakscott.com/wordpress/?p=1518 ]There are People out there getting inventive[/url]
Posted : 30/10/2014 2:59 pm
Older SRAM shifters work with the Zee mech, I"m using an x5 8 speed.
Maybe some sram roadie shifters have 1:1 actuation ratio?
Posted : 30/10/2014 3:00 pm
Do SRAM drop bar shifters use the same cable pull as their MTB shifters though?
Posted : 30/10/2014 3:06 pm
