Zee rear derailleur...
[Closed] Zee rear derailleur issues- how do I know I've been sent the right one?
[#6217188]
As above really, are there any distinguishing marks on the bodies themselves to tell whether I have the 36t or 28t version? Box it came in (bought new) has a tick in the 36t box but i'm buggered if I can get it to shift into the top sprockets on my 11-36 10spd cassette. Could some unobservant lackey have ticked the wrong box or am I just shite? I've changed a number of xt and deore derailleurs with no issues, this is my first zee though and one with shadow plus (lah dee dah, i know) and the clutch is turned off for installation.
After two hours of faffing i'm losing the will to live, thought i'd best crack out the ale and have a minute away from it and consult the hive mind.
Ta for reading if you got this far.
Posted : 24/05/2014 4:35 pm
What have you tried faffing with?
Limit screw set correct? Does it shift to 36 with no cable and just pushing it up with your fingers?
Posted : 24/05/2014 4:39 pm
The mech is the same either version.
The difference is in the bracket that attaches it to the frame - if you look at it it's blank for the fr version and stamped dh for the dh version. If it's dh you'll need the other bracket.
Posted : 24/05/2014 4:44 pm
 chip
I fitted a zee to my hardtail this morning.
Running a 36 up front and 11-40 on the back .
The box was ticked fr (36), on inspection I saw DH cast into the back of it somewhere which made me a little concerned but fitted and works fine .
When first bolted on it would only move 6 or so clicks in which was because the l screw was wound far too far in.
Set the screws and indexed perfectly.
Posted : 24/05/2014 4:49 pm
I've had a long cage shimano xt rear mech delivered before when it was clearly marked as medium on the box so possibly a packing an error!
Posted : 24/05/2014 4:52 pm
 chip
Here's mine it says DH on the bracket. I am worried now, although it works perfect on an 11-40
Posted : 24/05/2014 5:01 pm
Thanks for the replies guys.
Runs fine in smallest cog then when I shift it up its ok till the 8th gear then jams up. B screw adjustment just pulls the cage into the biggest rear cog if i try to give it any movement. Going to put a bit of extra chain in, see if that gives it a bit more room to manoeuvre. Not able to push it all way up with cable off, can't see a DH stamp on it though 😕
Posted : 24/05/2014 5:08 pm
 chip
Have you let the L screw out any?
Posted : 24/05/2014 5:13 pm
The L screw is all the way out, just linking chain back up then I'll give it another whirl.
Posted : 24/05/2014 5:19 pm
Turns out I'm just shite 😳 Took too much chain out at first, adjusted n running sweet.
Cheers dudes.
Posted : 24/05/2014 5:25 pm
