Yt Capra/hope brake...
[Closed] Yt Capra/hope brakes
[#7688329]
Anyone running a tech 3 E4/V4 setup on their Capra ?
Got the correct HOPE (C) mounts front has bolted on perfect to the pike, having trouble with the rear when calliper bolted down disc fouls on the underside of the calliper so disc won't turn not a few MM eithier it's quite a bit so shimming won't solve it. Tried mount other way it's even worse !
Posted : 04/03/2016 9:50 pm
All hope parts !
Posted : 04/03/2016 9:51 pm
Sounds like 183mm rotors!
Posted : 05/03/2016 12:44 am
Not gonna be when he's got 203 mounts.
Have you tried changing the front mount for the rear? Possibly one is out of spec, or is actually a 183 or 180.
If swapping doesn't fix it, get some photos taken and post them up here.
Posted : 05/03/2016 1:16 am
didnt hope do a 205mm rotor once
Posted : 05/03/2016 2:27 am
Mounts are identical hope post to post c had them side by side they match. Rotor is a hope 203 brand new bought yesterday. It's as if the frame post mount is in wrong position yet I had no trouble with the SRAM guides that came with the bike with centreline rotors 200mm
I'll get some pics later
Posted : 05/03/2016 9:41 am
Problem solved rear post on Capra is 180mm not the standard 160mm so 203 mount is wrong on I need the 183 mount H so it'll space it out 23 mm
Posted : 05/03/2016 4:14 pm
