Your project for to...
[Closed] Your project for today - help me find some cheap internal racking for my van
[#4939175]
Or give me ideas of how you do it.
I don't want the bikes to be taken apart as that sort of negates the idea of having a van....
So far I'm contemplating something like [url= http://www.utahmountainbiking.com/goodies/TruckbedBikeRack.htm ]this[/url] - but from pricing up the bits online it's coming out about £40-50, for the same price I could get 2 of [url= http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_251037_langId_-1_categoryId_165477 ]these.[/url]
Do you know if you you can just buy the clamps for those racks? As an alternative I'm thinking of installing a wheel grip on the bulkhead & a clamp on a hinge on the floor that will come up from the floor in the same style as a roof mounted carrier.
Any other ideas welcome!
Thanks
Posted : 08/03/2013 8:57 am
If you own the van I would make or buy something that secures the fork to the floor and then remove a wheel.
Using something like this
http://www.gripsport.com.au/product/fork-grip-15mm
Posted : 08/03/2013 9:07 am
I just use a couple of those cheap wheel grip stands fastened to the bulkhead and when I have the bikes in I just turn the front wheels through 90 degrees and fasten them together with a bungee.
They never seem to go anywhere. This is in a Fiat Doblo BTW.
Posted : 08/03/2013 9:09 am
When I had my van I just bungied them against the side.
Posted : 08/03/2013 9:10 am
Per Drac
Small supply of Removers blankets and some bungees. Really no need for anything fancier & makes the van interior far more flexible.
Unless it's a Team Van / you're trying to look the part 😉
Posted : 08/03/2013 9:13 am
Andy r - that's the other thing I was thinking of but was struggling to work out how to keep them in place looks like bungees are the answer.
Posted : 08/03/2013 9:49 am
They stay wedged in the wheel stands well enough - I just bungee the front wheels together (if I'm carrying two) for a bit more stabilty.
They can't really come out of the wheel stands anyway in my van as it's just the right length with the wheels turned through 90 degrees.
These are what I used - http://www.ebay.co.uk/itm/2X-Bicycle-mountain-bike-floor-wall-mounted-stand-rack-parking-rail-storage-/130636606950?pt=UK_SportGoods_CyclAcces_RL&hash=item1e6a8c6de6
Posted : 08/03/2013 10:47 am
How about a couple of [url= http://www.planet-x-bikes.co.uk/i/q/TOBSART50/bicisupport_stand_without_wheels ]these[/url]?
Seem a pretty good price for what you're after. If you wanted to make them a bit more stable but easy to remove you could even bolt them to a piece a floor board for not much more.
Posted : 08/03/2013 11:15 am
I used to transport my mx bikes by just wedging front wheel against bulkhead and strapping down. Those front wheel holder things just do the same thing and are ideal - we never really worried about the back wheel it never went anywhere.
For a mx you had to use straps to compress the front forks else a good bump and with the weight etc they would droop let the straps go and fall over. So make sure you put on your for lockout or use bungees under enough tension, course if you can rig it to just strap on the fork arch that'd do it.
Posted : 08/03/2013 11:23 am
Ooh I quite like those cheap wheel holders, could be just the ticket, was thinking ratchet straps as well...
Posted : 08/03/2013 11:33 am
If you mount the racks AndyR has highlighted vertically and ram the rear wheel in, compressing the tyre in, it should more or less stay put without having to tie anything down at all. The problem comes when you mount bikes by the front wheel and they can swivel about the headset bearings easily. Anchored by the rear wheel it's going nowhere
Posted : 08/03/2013 2:13 pm
How good are you at [url= http://forums.bicycletutor.com/thread-2482.html ]DIY[/url]?
Posted : 08/03/2013 2:46 pm
robarnold - Member
That's it exactly, as long as you have a bulkhead (or do like I did and build a half bulkhead out of 19mm ply) it's a perfect and cheap system
Posted : 08/03/2013 3:18 pm
