You can make one "s...
You can make one "standard" an actual standard
Cues is a good example of something that should have come in and completely replaced about 3-4 other groupsets in one go. But no, they did a “soft launch”, they’re still running it alongside Acera, Altus etc and the result is just more standards and compatibility issues.
We've got this problem in our company.  As long as something is still selling it's very difficult to convince managers to give it up.
It leads to incredibly convoluted product lines, not to mention confusion for consumers and even people working in the company itself.
In many cases, where there should be one product, there are four or five.
Posted : 23/08/2024 1:00 pm
Given how long those two lines have been going for, the production cost/item must be in the 10th of a penny, It'd be hard for any company to give up what must be pretty profitable lines that you see on very £200.00 BSO
Posted : 23/08/2024 1:15 pm
And Drop-bar levers were promised (still not materialised).
See also:
It just makes me suspect Cues is actually using Dynasis Cable pull with slightly tweaked sprocket spacing/cable pull increments to frustrate attempts at backwards compatibility.
Posted : 23/08/2024 1:31 pm
anyway, the Richter scale of measuring earthquakes seems like a pita.
Each decimal point on the scale represents a 10x difference in magnitude.
wtf? Are there any other units of measurement, designed to confuse peole?
How much louder is 20 decibels than 10? And why don't we ever deal in whole bels?
Posted : 23/08/2024 1:42 pm
wtf? Are there any other units of measurement, designed to confuse people?
do you actually care how much force is released in the ground movement? what would you do with that information anyway?
or do you want a nice number between 1 and 10 read out on the news so you can compare it to previous ones?
Posted : 23/08/2024 1:55 pm
kelvin and kelvin reacted
Headsets. Remember when you just went and bought the 1.125" headset you wanted. Now you need some kind of degree in engineering to understand what you have and what you need via deciphering some kind of cryptic language.
Posted : 23/08/2024 2:21 pm
Do you have a recommended standard for the accompanying ear defenders to stop all the creaking entering our  lugholes ?
I followed that up with "jokes aside" 😉
Posted : 23/08/2024 2:27 pm
Headsets. Remember when you just went and bought the 1.125″ headset you wanted. Now you need some kind of degree in engineering to understand what you have and what you need via deciphering some kind of cryptic language.
Same in BBs.
Square taper in about 3 different axle lengths, that was the lot!
I'm actually not that bothered about it - BBs last a long time (we'll ignore the anomaly of early generation ISIS!) and pretty much any modern BB is stiffer, stronger, lighter etc than any old square taper one ever was.
The more annoying thing is each manufacturer trying to convince the consumer that their system is the best one ever, often before quietly abandoning their much vaunted system 2-3 years later.
Posted : 23/08/2024 3:01 pm
I think what annoys me is that 10 years ago or so there was one standard for pretty much the entire drivetrain.
Since then every single drivetrain standard has changed.  And yet at a glance they look exactly the same as before.
If you're going to change every component in the drivetrain couldn't you use that as an opportunity to completely redesign it for a system that doesn't have all that unsprung mass on the back, requires the wheel strength to be compromised so the cogs can be fit in, and requires the suspension design to be compromised to mitigate chain stretch and pedal kickback?
Posted : 23/08/2024 3:15 pm
That's a good thing though, surely? A few things spring to mind. 1. the cassette/derailleur/chain design was clearly originally so good, it's remained both the predominate design for over a hundred years, and has just needed incremental tweaks to improve it. 2. Design happens in the present and not in the future. The designers in bike companies are looking to integrate new technology with existing designs it would take either a bold step to junk it all in favour of unproven technology, and not piss off every home mechanic in the universe, or a crystal ball.
Posted : 23/08/2024 4:23 pm
 1. the cassette/derailleur/chain design was clearly originally so good, it’s remained both the predominate design for over a hundred years, and has just needed incremental tweaks to improve it.
I'd say it's good for road bikes.
It's OK for hardtail mountain bikes
However, full suspension mountain bikes work well in spite of derailleurs, not because of them.
If you were designing a full suspension mountain bike from scratch I reckon you'd end up with a cassette in the centre of the cranks, another at the suspension pivot point, and something like a front derailleur cage with a lead screw and probably electronic control.  Like the phaser gearbox I posted earlier, with the cranks at the input side and a shaft with the main pivot around it. Then a single chain running to the rear wheel.
This configuration would look different but it would probably actually have fewer 'new' standards than the current incarnation of drivetrains.
Posted : 23/08/2024 4:41 pm
If you were designing a full suspension mountain bike from scratch I reckon you’d end up with a cassette in the centre of the cranks, another at the suspension pivot point, and something like a front derailleur cage with a lead screw and probably electronic control.
You're basically talking about a derailleur in a box, but without the box. Problem is that the chain is very short so the chainline is terrible in the extreme gears. It's possible to devise ways to build a compact chain based gearbox, but keeping the chainline reasonably straight adds complexity and expense. 1x derailleur systems with the cassette on the rear hub work are a pretty good and cheap compromise for most purposes, including suspension bikes.
Posted : 25/08/2024 3:40 pm
Re: Richter scale
yes, it would be nice to articulate seismic magnitudes into something that Joe Public can understand.
anyway, bicycle light fittings for rear racks, handlebars and helmets.
the time I’ve spent trying to zip-tie rear lights to racks.
go-pro and/or Garmin should be standardised.
Or at least go-pro for helmet mounted accessories.
theres enough turnover of lights for topeak and other manufacturers if pannier racks to introduce go-pro prongs as their new standard.
Posted : 25/08/2024 4:12 pm
Bring back 20mm pinch bolted axles to 160/180 forks
Posted : 25/08/2024 5:47 pm
You’re basically talking about a derailleur in a box, but without the box.
No, I'm talking about two cassettes (same number if teeth on corresponding cogs).  See the phaser gearbox.
It has been done as a proof of concept a few times. Also, Shimano's patent from a couple of years ago was basically the same thing but with three axles instead of two for some reason
Surely I can't be the only person who saw the first idler high single pivot bikes come out, with new cassette standard, new derailleur standard, new chainring, etc and thought, 'OK, this is getting silly. Can't we just throw everything out and design it properly since every part has been changed anyway.'
Posted : 25/08/2024 6:44 pm
^ I think if Shimano or SRAM had as long a view of bike trends as their own product development map they might have put more into mech-in-box systems. Mech momentum is against them, still it does seem to be a good match to idler bikes. Ted James's Alfine bike from about 2010 jumps to mind.
Posted : 25/08/2024 7:39 pm
Not so much everything has to be somethings as everything shouldn't be anything. Black!  Acceptable on tyre treads and possibly cable outers but otherwise no.  Black spokes FFS or rims or mechs! Designed by kids who are too lazy to get the coloured pencils out. Well the silver one.
Posted : 25/08/2024 10:41 pm
And for all those pushing the BSA BB, when Shimano introduced the HT2 they were absolutely s***e, no end of complaints and how Square Taper was better etc.
Were there? Not from where I was standing, everyone was doing their damnest to pick up Saint/XT or Hone/LX and ditch the square taper and ISIS.
Posted : 26/08/2024 2:21 am
jameso, kelvin, kelvin and 1 people reacted
Square taper thank the lord are a thing of yesterdecade
Posted : 26/08/2024 2:33 am
Not for me, both of my bikes have square taper and both are fine. The BBs last for years and years, in fact the BB on one of my bikes is 34 years old.
Posted : 26/08/2024 7:27 am
For all it's theoretical faults, the derailleur is still the least compromised, gearboxes weigh more, cost more, and drag more, although I can see them being popular in e-bike where the natural disadvantages of gearboxes can be minimized by motors
Posted : 26/08/2024 8:26 am
thols2, kelvin, kelvin and 1 people reacted
^ Oh agreed, std mechs work just fine in all but the absolute worst conditions. Considering the bikes that are best suited to idlers, motor gearboxes are the way forward. That assumes enduro type bikes will me mainly e-bikes in due course.
Posted : 26/08/2024 8:49 am
I think it really depends what you mean by gearbox.  Personally I class gearboxes as anything that involves solid gears meshing somehow.  So basically anything like the pinion but also all the internal hub gears (including clever solutions like NuVinci even though it doesn't technically mesh).  I think gearboxes come with an inherent loss of direct connection that I don't like for mountain biking.  The main thing I like about them is the robustness and lack of maintenance.
I wouldn't really class the attempts like the Phaser, the Honda gearbox, Williams Racing Products, and the Lal drive as gearboxes though.  I tend to think of them as just taking standard components and rearranging them so as they are better suited to mountain biking.
Overall I'm not too keen on gearboxes for mountain biking (although they do make sense with ebikes).  However, I am very keen on rearranging the components so that we don't have so much delicate hardware dangling off the back.  Not to mention the suspension design compromises needed to run a rear derailleur.
That's my main complaint.  All the components were changed and yet they were left in exactly the same configuration.  Obviously this happened because component changes happened one at a time.  But then they must have had an inkling all these changes were coming.  Couldn't they just have said, 'All these things are going to change over the next few years so we're just going to move them around while we're doing it.
Posted : 26/08/2024 9:10 am
I'm surprised T47 BB hasn't featured on more frames seeing as most people hate press fit, most aftermarket cranks are 30mm axle and most bikes come with SRAM spec instead of Shimano so it's mostly OEM dub cranks out there.
As already mentioned who decided stanchions, rims, spokes, cranks and mechs should all be black, remember when Shimano had the option of silver.
Posted : 26/08/2024 10:22 am
All the components were changed and yet they were left in exactly the same configuration.  Obviously this happened because component changes happened one at a time.  But then they must have had an inkling all these changes were coming.  Couldn’t they just have said, ‘All these things are going to change over the next few years so we’re just going to move them around while we’re doing it.
It's much harder to rearrange them than you seem to assume. It's not impossible, but it will be more expensive and trying to cram a derailleur based transmission into the frame will compromise suspension design, especially for small sized frames.
Posted : 26/08/2024 10:29 am
I have 7 bikes but the only one that really annoys me are freehubs.
Posted : 26/08/2024 4:04 pm
Derailleur hangers - especially now that a slightly bent one has an impact on shifting and the ability to throw an expensive mech into a wheel, having lots of simple spares on hand will make riding better
Posted : 26/08/2024 8:21 pm
Anyway, I'd just restandardise freehubs as HG. If you want a bigger top end just get a bigger chainring. If you can't hack the bottom end git gud.
Posted : 27/08/2024 12:56 am
Nah, chewed up too many alloy hg freehubs to ever go back, microspline for me thanks.
Posted : 27/08/2024 1:25 am
I’m surprised T47 BB hasn’t featured on more frames seeing as most people hate press fit, most aftermarket cranks are 30mm axle and most bikes come with SRAM spec instead of Shimano so it’s mostly OEM dub cranks out there.
All my cranks are 24mm… what am I missing out on by not having 30mm (or ‘almost`’ 30mm)?
Posted : 27/08/2024 6:58 am
I've seen things you people wouldn't believe... Square taper axles snapped off a 10 foot drop... I watched Octalink shred their splines near the Tannhäuser Gate. All those moments will be lost in time, like tears in rain... Time to die.
Posted : 27/08/2024 8:59 am
kimbers, nickc, kimbers and 1 people reacted
Didn’t Rockshox invent the Torque Cap because they were admitting a 15mm front axle wasn’t stiff enough?
to try and combat the noodle-y nature of the USD RS-1 fork. With limited to no success. They then rolled it out across the range.
Posted : 27/08/2024 9:19 am
I rode one of those a few miles and back along a v gentle greeny/blue trail once, and was mesmerised by the legs compressing and extending independently of each other. I couldn't imagine using it in anger. Looked super cool though
Posted : 27/08/2024 9:29 am
Brake pads. I have multiple bikes and all of them have different pads. My Canyon FS has different pads front and rear despite both being SLX!
You'd probably need a few road, XC/gravel and DH. But not one for every caliper ever invented.
Posted : 27/08/2024 9:32 am
kimbers, clubby, clubby and 1 people reacted
That's the manufacturers fault not the standard. Stop buying aluminium and have a decent shit before you go out or ditch the dropper if that weight matters so much.
Posted : 27/08/2024 11:59 am
For me, having just spent yesterday swapping bits between between frames, its bolts! 3mm on one cover cap then 2.5mm on the next. 4mm on stem bolts then 5mm on the stem cap, then 6mm on the Hope stem cap. 6mm on the bolt thru, then oh no this one is 5mm. 4mm for this seat post clamp, 5mm on a different one.... 4mm on shifter and brakes clamps but 3mm for dropper post bar clamp
At least all the rotor bolts are torqs......nope this one is 3mm hex!!!!
**** off!!!....
Posted : 27/08/2024 12:11 pm
jameso and jameso reacted
I just got one of those bargain Pro 5 hubs and I went for the steel HG freehub, I'm staying on 11sp and fancied a change from XD.
I know, cool story bro.
Posted : 27/08/2024 12:13 pm
Square taper BBs are great for bikes that do long distances year-round. 100% valid format, just not for many MTBs. Would have one on my SS MTB though because it eats HT2 BBs.
Posted : 27/08/2024 12:57 pm
20mm is still the one that pisses me off and also the one that made it clear that customers have no meaningful buying power whatsoever, because we buy a handful of forks in our lifetime while Trek and Specialized buy them by the container. Boost is almost as bad but I reckon if we could travel back in time and kill 15mm Hitler, whoever that was, we could probably avert Boost into the bargain because winning that first battle would have stopped them doing it again, and again, and again.
But actually i'll go the way of tiny changes, and say 31.8 stems. Because not only is 35mm pretty pointless anyway, and inferior in that it can't be as short, it's made buying stems and bars super annoying because the thing you want is ALWAYS available and ALWAYS on discount in whatever size you don't want. But most of all because combined with modern "show you something slightly different from what you asked for" search algorithms it's made buying short stems an absolute nightmare.
Posted : 27/08/2024 8:03 pm
ads678, squirrelking, ChrisL and 5 people reacted
Not sure why but that made me do a genuine LOL in the middle of the office 🙂
 it’s made buying stems and bars super annoying because the thing you want is ALWAYS available and ALWAYS on discount in whatever size you don’t want.
I've said it before but my preferred way of buying a bike 10 (or maybe closer to 15 now) years ago was to buy the frame, then go to CRC and 'sort by discount first' to find the components.
I might not have a bike that was optimised to within an inch of it's life but I could prioritise the important parts for me and end up with a bike that was not that much different in term of value for money when compared to complete bikes.
In recent years that just wasn't practical.  While there were still plenty of components available for 70+% off, it's almost always impossible to find the standard you want.
Posted : 28/08/2024 8:48 am
Same here Kelvin, I've always had XT after XT after XT, my frames are always threaded BB, it's a deal breaker, but if any frames on my short list changed to T47 in the next iteration I might try a different crank.
Posted : 28/08/2024 9:05 am
 it’s almost always impossible to find the standard you want.
I've just done this building a Yeti frame, and it's got all sorts of new sizes, - 55mm chainline, and PF BB, to name a couple and it was easier to buy those things than it was to find the fork I wanted, or the saddle.
Posted : 28/08/2024 9:40 am
I’ve just done this building a Yeti frame, and it’s got all sorts of new sizes, – 55mm chainline, and PF BB, to name a couple and it was easier to buy those things than it was to find the fork I wanted, or the saddle.
Sure, you can find any part you want, regardless of standard.  I was reading Gironimo the other day and he managed to find someone to make him a pair of wooden rims.
What you can't do today is buy a frame and find all the parts for it all with a minimum of 70% off.
You can find an example of every component with 70% off, but they most likely won't be the standard you need.
Posted : 28/08/2024 9:47 am
BruceWeeFull
I’ve said it before but my preferred way of buying a bike 10 (or maybe closer to 15 now) years ago was to buy the frame, then go to CRC and ‘sort by discount first’ to find the components.
Same here, partly out of necessity to keep cost down, partly because I had a slightly deranged obsession with putting the bike together cheaply and I'd have spreadsheets of parts and price and postage costs and weight as I tried to figure it all out. Always found it a strangely absorbing and theraputic process, planning it all out.
Posted : 28/08/2024 9:49 am
Quite liked square taper bb's. Bearings lasted years and loads of different lengths to choose from. Never had an issue with them but did see plenty of crank arms rounded where they had been ridden lose.
Posted : 28/08/2024 10:12 am
Page 3 / 4
