Any built an ASR5 recently?
I was building one up for t'missus last night, and was a bit puzzled by the internal routing in the chainstay for the rear mech.
Is it supposed to be for a full length outer, or just a bare inner with ferrules at either end? Looks a bit narrow for outer.
Cheers,
Dave
Full outer, unless you want the cable sawing through your swingarm.
It does fit.
cool, that is good to know.
any tips on feeding it through? it has the bit of thin hose in from the factory - do I just tape my sp41 to the end of that and feed it through?
Dave
I can't help with that I'm afraid but I'll await with interest someone who can - mine arrived pre-built.
One tip - once you've done it that piece of cable outer(on mine anyway)is narrower than the others meaning the clamps on the downtube don't hold it. It then gradually feeds itself toward the rear mech when riding. Easily fix by wrapping some (insulating) tape of the same colour around the cable outer where it fits to the lowest cable clamp, once you have the cable positioned correctely.
Hmm, not had that problem with cable migration, but then I'm running Gore outers which are a bit thicker anyway...
Useful stuff [url= http://yeticycles.com/#/support/manuals ]here[/url].
They always show cable routing advice in the manuals.
I didn't even consider looking at the manual... that sounds like a sensible thing to do 😳
The manual is good, but it doesn't actually tell you how to pull the outer through the chainstay. If you haven't done anything like that before, or any electrical installations where you pull cables then its not obvious. The important thing is to first remove the plastic guide at the back of the chain stay (which the manual does mention TBF). You can use some strong tape to connect the cable outer to the piece of plastic that is already through the chainstay and carefully pull it through.
The problem is if you use too much tape it will be too big to pull it all through. If you dont use enough tape, it wont hold.
In the end I didn't bother with the piece already through the chainstay, its not needed. I just inserted the outer into the chainstay, gently pushed it through and it pretty much came straight out the hole the other end. I think I used some tweezers to just help it through.
Hope this helps
Thanks all, I'll finish building it tonight.
Of course, please post the obligatory picture when you're done 🙂
Good luck.
remove the plastic guides either end of the swing arm
feed cable inner through black tube in swingarm
remove black tube
feed outer over inner
hey presto, et voila etc etc
You don't put the black tube back? I thought that was there to stop the cable rubbing against the carbon inside the swingarm...?
he means the factory 'placeholder' tube... once you've got an outer running through there, you won't have either space or need for it.
Dave
correct - the tube is jut to feed the cable through, bin it after
also - when changing cables - :
leave outer in
pull out inner
feed new inner through old outer
pull out old outer
feed new outer over new inner
I just removed the stoppers and stuffed the outer down the swing arm. At the mech end I used a small allen key to hook the end and lift it out.
There's lots of room; and I can't be arsed getting new cables covered in old cable crap.
