yeti 575 ownwrs
[Closed] yeti 575 ownwrs
[#2980027]
I have a 2009 yeti 575. I am thinking of running some larger tyres for the alps.What are the largest tyres you have run?
Posted : 25/07/2011 2:46 pm
 ben
I' ve got a 2.25 Maxxis Ardent on mine and I wouldn't want to go much bigger tbh.
Posted : 25/07/2011 2:48 pm
yeti 575 ownwrs...
...are queuing up to trade them in for SB-66s 🙂
Posted : 25/07/2011 3:02 pm
 P20
I don't if the 09 has more clearance than the older shape 07, but i found 2.4 nobby nic fitted, but the flex in the swingarm, wheel and sidewall meant it rubbed during hard cornering. 2.25 fits no problem
Posted : 25/07/2011 3:21 pm
They officially have a 2.5 max. I reckon a 2.3 would be pushing it though.
[i]..are queuing up to trade them in for SB-66s[/i]
With all this nonsense going on, I think not!
Posted : 25/07/2011 3:25 pm
Long live the 575. Don't really like the look of the SB66.
Posted : 25/07/2011 8:55 pm
2.35 Maxxis (High Roller and Minion), seem fine to me.
Posted : 25/07/2011 8:58 pm
I like the look of the new SB66 especially after seeing it in the flesh but thats the first time I've seen it "naked" and I must admit it sort of worries me. I've no doubt it works but like a lot of suspension systems, when you actually live with them months on end you soon learn sometimes things aren't always as they should be.
Posted : 25/07/2011 9:21 pm
 ahsf
if you have a cabon rear end it will flex alot an 2.5 tyres will wear the stays (not good seen a few snap from this)the alloy rear end is stiffer so maybe ok with 2.5.
i allways run 2.35 minons with a carbon rear end and could still get them to rub but only when railing the berms flat out with 30psi tyre pressure but it was never an issue after 2 mega avalanche an 4 trips to the alps. (i weigh 11st so if your weight is more the rear end may flex more hope this helps).
Posted : 25/07/2011 9:26 pm
