Yet another Reverb ...
[Closed] Yet another Reverb question
[#6891039]
My Reverb is just under a year old, so still in warranty. It's started to drop about half an inch when I put weight in it. I spoke to the shop I bought it from, and they suggested bleeding it, which I did, not really expecting much change. The bleed seems to have almost cured the problem - it now only drops a couple of mil. Worth trying again with the bleeding or is it masking something more serious?
Posted : 25/02/2015 11:33 pm
Have you checked the pressure? Sounds like it could need topping up (250psi from memory)
Posted : 25/02/2015 11:38 pm
the ifp seals have gone and fluid is getting into the air chamber .
i bet if you let all the air out there will be some fluid in it .
the seals need changing , and if it is still under warranty do it now .
the problem will come back .
The instructions on my Reverb tell me not to touch the air pressure otherwise I invalidate the warranty and cause a complete service to be required, with likely death occurring imminently...
Posted : 26/02/2015 12:01 am
The half an inch drop seem to be a problem which will get you a no questions asked warranty replacement. You could spend money on a service and repair yourself if your prefer to save a few week seatpostless wait.
I've had two replaced after a years use due to this issue. It's worth Bleeding (which you've done) and checking pressure is at 250psi first though.
Posted : 26/02/2015 12:15 am
It's only a couple of mm drop now after lots of bleeding, but I can't get rid of that. I have checked the pressure aye, first thing I did
Posted : 26/02/2015 9:56 am
