Yet another M785 br...
[Closed] Yet another M785 brake thread
[#4627250]
But without the normal question.
How often is 'normal' between bleeds? I've had mine since february and they feel like they could use a bleed, but I have had to swap the hoses over as I bought them from Germany.
Just, please, this cannot be the start of what I had with my avids again of having to bleed them at least once a month.
Posted : 05/12/2012 11:48 pm
bleed them from bottom up, put new hoses on mine , syringed the fluid through, no need to pump, perfick
Posted : 06/12/2012 12:02 am
If they're bled properly, it's not normal to need bleeding again unless you have a leak somewhere. Check both of your caliper pistons are moving freely, and are centred properly on the rotor, as this can cause poor lever feel.
Posted : 06/12/2012 8:32 am
Shimanos dont feel as nice when the pads are worn either.
Posted : 06/12/2012 9:35 am
Cheers chaps. Think I'll try changing the pads first, and just see if it's is just because they're starting to wear a bit. Will still need to trim to hoses at some point though, but I can put that off for another 8 months 😛
Posted : 06/12/2012 9:58 am
