Yellow tape
[Closed] Yellow tape
[#6046100]
When should I replace the yellow tape in my tlr rims? Is it when I replace the latex or when I change tyres or some other time?
I've seen gorilla tape mentioned, is it a viable and cheaper alternative?
Sorry for mulit questions but I'e been using ust rims until recently 😕
Posted : 18/03/2014 3:25 pm
I've used the 1" wide Gorilla tape on my LB rims, and it was a perfect fit. You'd have to trim it on many rims, which would be a bit of a pain, but not insurmountable.
I only replace it when it get really manky, IME eventually you get some sealant under it and it stops sticking. That generally takes years rather than months though.
Posted : 18/03/2014 3:57 pm
Cheers. The wheels are only about 4 months old but I'll keep an eye on the tape at tyre change(more frequent than sealant change) 😀
Posted : 18/03/2014 4:08 pm
As above, replace it when it needs replaced, not before. Sometimes it can peel or fold a little over time- gets sealant under it, or gets pushed to one side when you change tyres. But rare, that. I think the most common cause for me is replacing spokes.
Posted : 18/03/2014 4:19 pm
